Author Topic: restoring the appearance of an 8-3/4 center section  (Read 1062 times)
Offline Tonefiend
  • '70 Challenger
    • Ian A. Guitars
« on: November 05, 2009 - 04:13:21 AM »
My 8-3/4 center section has the original unfinished look to it with all the factory markings, however the years have not been kind.  What is the best home remedy to restore it to a new appearance?  Can I use stripper, or an aluminum mag wheel clearner to clean the metal?  I have no access time or money to have it bead blasted.   Then whats the best coating?
Re: restoring the appearance of an 8-3/4 center section
« Reply #1 on: November 05, 2009 - 12:05:07 PM »
wire brush & high heat cast grey paint
Offline Tonefiend
  • '70 Challenger
    • Ian A. Guitars
« Reply #2 on: November 05, 2009 - 12:39:23 PM »
Thanks Cryco!
Offline tactransman
« Reply #3 on: November 05, 2009 - 10:01:57 PM »
Terry-tactransman
Union, Mo.
Offline Tonefiend
  • '70 Challenger
    • Ian A. Guitars
« Reply #4 on: November 06, 2009 - 02:20:17 AM »
Thanks, got a couple cans incoming!
Offline Tonefiend
  • '70 Challenger
    • Ian A. Guitars
« Reply #5 on: November 06, 2009 - 10:51:09 PM »
Where is the best place to get rear seals, gaskets and some other assorted odds and ends for the rear end?
« Reply #6 on: November 07, 2009 - 04:15:15 AM »
Local parts house had the pinion seal in stock, ordered the axle & dust gaskets they overnight, all less than $20 the gaskets were Felpro & the seal I believe was Federal. Didn't replace the axle seals but they should be no problem if you need them.
