Steering following road?
Author Topic: Steering following road?  (Read 4702 times)
Offline punisher72
  • 70Challenger 440 4 speed yeeehaaaaa!!!!!!!
« on: November 06, 2009 - 01:36:18 AM »
Hello again guys. i love this site :bananasmi  Ive just had my front end done up and the bushes in the rear of my chall with power steering. Problem is still there from before is it tends to wonder from side to side like its following the road dips and hollows???????? Is this something that can be fixed like the previous post regarding the valves and stuff in the power steering? Any help very appreciated for this un educated mopar driver  :2thumbs: :cheers:
Offline hooD
  • detroit iron
  • Motor City Made Muscle
Re: Steering following road?
« Reply #1 on: November 06, 2009 - 02:21:44 AM »
what kind of tires are you running?  I have bias ply's on my cuda and they do not handle as well as radials do.  Mine also tend to follow the wear pattern in the road like you mentioned.  Just my 2¢
« Last Edit: November 06, 2009 - 02:25:07 AM by hooD »
-Larry
member since AUG 2007
southeastern michigan usa
1973 'CUDA 340
original owner
37,117 miles
Offline mopardave
  • Sponsor
    • rosevillemoparts
« Reply #2 on: November 06, 2009 - 07:57:35 AM »
have you checked the coupler? adjusted the gear? if you have the gear may need to be rebuilt.
Mopar Dave
Rosevillemoparts.com
70 FK5 Challenger RT/SE
70 FC7 70 Road Runner - Sold
71 FM3 Challenger RT
73 F8 Challenger
1990 XJ - sold
2000 Dakota Quad Cab
Offline ericindc
« Reply #3 on: November 06, 2009 - 10:51:53 AM »
My challenger does the same thing.  The only other car i've had that did that was my first car, a 68 dodge coronet.  Its downright scary when you are on the highway and it starts doing that.  Any quick fixes would really help me out also.
1974 Challenger, 440, auto, 17s
1983 Jeep CJ7, Chevy 350, auto, 32" tires, 2.5" lift
Offline 6packCuda
« Reply #4 on: November 06, 2009 - 02:16:20 PM »
I'm assuming that you had the front end aligned when you had the front end done up?
Alaskan_TA
« Reply #5 on: November 06, 2009 - 06:06:49 PM »
Bias ply tires are infamous for that.
Offline Changin Gears
« Reply #6 on: November 06, 2009 - 06:12:50 PM »
How much castor are you running?  More is better, like 2.5-3 degrees.
Offline BIGSHCLUNK
« Reply #7 on: November 06, 2009 - 08:54:13 PM »
Sounds like bias -plys to me....
                                             [o o o o]
                                                  OO
                                                  OO
                                              [o o o o]
Offline punisher72
« Reply #8 on: November 07, 2009 - 02:38:22 PM »
Thanks heaps for the replys. My front tyres are :dunlop sport 5000 245/40 zr18. The rears are :wanli 275/35zr 20 102w xl??????. The castor i dont know about? The guy that did it has been working on valiants dodges and so on for yrs. I will find that out... Mopar Dave,What do you mean by have i adjusted the gear  :clueless: Thanks again  :cheers: I will get back to you as soon as i can bout castor.
Alaskan_TA
« Reply #9 on: November 07, 2009 - 04:14:47 PM »
So, are they radials or bias-ply?
....and what is on the rear? Running bias ply tires on one end with radials on the other can be very unsafe.
Offline bordin34
« Reply #10 on: November 08, 2009 - 12:14:59 AM »
I think they are radial because of the the r before the rim size what the z means I have no idea.
1973 Charger SE Brougham Black 400 auto
1974 Charger SE Brougham Blue 318 auto-SOLD
Offline punisher72
« Reply #11 on: November 08, 2009 - 03:45:43 AM »
im not sure what they are? i will find that out too! :bigsmile:
Offline 6packCuda
« Reply #12 on: November 08, 2009 - 07:37:09 AM »
Those are radials.
« Reply #13 on: November 08, 2009 - 11:21:25 AM »
275 mm width, 35 series aspect ratio, z speed rating over 149 mph, radial, 20" rim, 102w xl is the revised speed rating equal to the W range of 168 mph or what a number of dealers are now calling "ultra" performance tires.
Punisher72, you had the front suspension done up. What does "done up" entail? There is a large combination of parts in the front end that contribute to stability, so we need to know what parts were replaced. A simple bushing replacement does not address all the possible wear points in the front end that can cause directional stability issues.This can help lead us in to possibile problem areas. This is important to know since you had this problem before the work was done. Odds are you had other issues that the rebuild work did not address.
Additionally, all the alignment specs are helpful to know as well. These can have a big impact on directional stability and we be able to recommend changes to assist in resolution.
Offline punisher72
« Reply #14 on: November 09, 2009 - 04:20:45 AM »
Thankyou HP2. The parts i had replaced are 4 tierod ends,pitman arm, idler arm,lower ball joints,upper ball joints,lower control arm bushes and swaybar bushes. The rest of the rubbers bushes were all fine. Also the rear spring bushes were replaced. Im not sure on wheel alignment specs. The guy said they use lasers and dont do printout sheets? But he also said bring it back and they will go over it all for me  :cheers:  Before i finish the front tyres are some never go flat ones? When punctured you can still drive on them as they have a very stiff wall either side.
