Home
Member Rides
Forum
Sponsor Sites
Tools
Contact
News:
Home
Help
Search
Chat
Login
Register
Cuda-Challenger.com
Chryco's Tech Shop
The Body Shop
(Moderator:
Chryco Psycho
Rear Window Molding Clips
« previous
next »
Print
Pages: [
1
Author
Topic: Rear Window Molding Clips (Read 1047 times)
cjm
Jr. Member
70 Cuda - In Progress.....
on:
November 06, 2009 - 03:14:24 PM »
Do you have to remove the rear window (70 Cuda) to install the clips for the molding?
Logged
http://www.cuda-challenger.com/cc/index.php?action=dlattach;attach=87989;type=avatar
Alaskan_TA
Guest
Re: Rear Window Molding Clips
Reply #1 on:
November 06, 2009 - 05:37:03 PM »
Yes. They are held in with philips head screws, no way to get to them with the glass in place.
Logged
cjm
Jr. Member
Reply #2 on:
November 06, 2009 - 08:01:38 PM »
So, remove the window, put the screws in, install the window, pu the clips on, install the molding??? Now, if I can just figure out how to get the window out without breaking it.... or should I just leave this one to the professionals........
Logged
quapman
Resident
Reply #3 on:
November 06, 2009 - 08:09:35 PM »
Utility knife and several new blades should do the trick. Oh, and a lot of patience.
I do not recommend using the wire method.
Logged
e-tek
Jr. Member
My website: http://edanneberg.googlepages.com/home
Reply #4 on:
November 06, 2009 - 09:46:37 PM »
I have restored MANY cars and do EVERY SINGLE bit of them myself, with the notable exceptions of engine machine work and removal/installation glass!! Too easy to break a slab of glass either taking it out or installing. As well, they use a hot knife to cut the butyl sealer...way easier than a knife or cold cutter.
Logged
My Challenger build:
http://www.cuda-challenger.com/cc/index.php?topic=49232.0
Alaskan_TA
Guest
Reply #5 on:
November 06, 2009 - 09:56:16 PM »
You have to install the clips with the screws.
Logged
wally426ci
Sr. Resident
Reply #6 on:
November 07, 2009 - 09:58:51 AM »
I heat up a putty knife with a torch.
Logged
{OOI====I====IOO}
'71 Challenger
[O[]=====[]O]
'68 D100
e-tek
Jr. Member
Reply #7 on:
November 07, 2009 - 10:37:08 AM »
Quote from: wally426ci on November 07, 2009 - 09:58:51 AM
that'll certainly work - but one chip or crack does a replacement make! no problem if you're replacing anyways, but i find it less expensive in the long run to have the pro's remove and replace, plus they gaurantee against leaks, have the right screws/clips and rarely bend the trim getting it back on!
Logged
Print
Pages: [
1
« previous
next »
Cuda-Challenger.com
Chryco's Tech Shop
The Body Shop
(Moderator:
Chryco Psycho
