Author Topic: Want to replace 4:10's with 3:55's  (Read 815 times)
Offline EbodyPro572
  • "Always restore, NEVER discard!"
« on: November 08, 2009 - 11:57:20 AM »
Since I am going with a 572 aluminum Hemi (by Tim Banning, FHO Hemi's) in my 73 Challenger, I want to change out my 4:10's with probably 3:55's or so.  Any suggestions on this or should i even go to 3:23's?  The car will have a ton of torque.  Any suggestions of brand/vendor, etc.?  Thanks, Scott
'ALWAYS Restore.....NEVER Discard'
73 Challenger; 04 Rumble Bee (Yello, of course); 01 Vehicross (Yello, of course, too); 90 Allante' (not Yello, just red); 79 MGB-V8; 68 Century Resorter;
73 Marlin Ski (468" Olds) Jet Boat; 06 Harley Fat Boy CVO; 73 Yamaha Golf Cart (Yello, of course); 07 Sears Garden Tractor
Offline Katfish
  • 70 Challenger
Re: Want to replace 4:10's with 3:55's
« Reply #1 on: November 08, 2009 - 12:12:50 PM »
3.55 should be a good choice.  I went from 3.55 to 3.73 and very happy.  All depends on what kind of driving you do.
Either way, Dr Diff is great.
http://www.doctordiff.com/
« Reply #2 on: November 08, 2009 - 12:21:34 PM »
So you have an 8 3/4 rear end?  With the 572 did you consider dana 60?  I went from 354 dana to installing 410's Im happy with the throttle response but busy at the shifter...which is fun to :2thumbs:  I see katfish installed 373/s  I just got a set that size for my dana too, i'm wanting to try out. Might be better for rpm cruising with a 27.5 tall tire.
355's will be a good cruising gear for you, but 410's are a blast and if you can hang around 3500 rpms, then no problems either. But your cooling system works a little more
Offline Ck[FIN]
  • Get real - Get Mopar
    • Small car club from Finland
« Reply #3 on: November 09, 2009 - 01:15:52 PM »
I would say that the 3.23 gears would be very nice also. I have driven a 468cid chevy with lots of torque, it had 2.73 gears. It runs like hell and has absolutely no traction with street tires. And awesome to cruise with 1800rpm  :roflsmiley:
Offline 422STROKER
  • Member Since 6/3/06
« Reply #4 on: November 09, 2009 - 06:44:00 PM »
If you are going to drive more than race, then the 3.23's or even some 2.94's.
I got a little Stroker and 3.23's and plenty of fun with low traction from a start.
Tom
Tom
Offline moparmaniac59
  • Drive it like ya stole it!
« Reply #5 on: November 09, 2009 - 08:27:25 PM »
I am running 3:91 gears (8 3/4 rear) with a 543 cid stroker and like Al says, a bit of shifting, but OK. It's about 2900 rpm at 60 mph with 295-50-15's. Not too good on gas, but for the most part the longest cruises I do are about an hour or so. I think 3:55's are a good choice! :2thumbs: With a 572, I would think you'd want a Dana 60. My 543 puts out 651 ft/lbs of torque. Enough to tear up my 8 3/4. I would think you might have even more torque. I am currently trying to score a Dana 60 myself. Good luck with the project!! :woo:
                                                  Matt B.
Matt
« Reply #6 on: November 09, 2009 - 09:10:48 PM »
I do not believe the 3.23 gears are available new so you would need a good used set
Offline Ck[FIN]
« Reply #7 on: November 10, 2009 - 08:41:01 AM »
If you have 489 case, here is a set for you
http://chucker54.stores.yahoo.net/choem8489car.html
