Author Topic: Glove Box Finish - Flat or Semi Flat?  (Read 2314 times)
Offline cwestra
« on: November 09, 2009 - 10:41:43 AM »
What is the correct finish for glove box door and surrounding metal surface?  It appears to be flat but want to be sure.  Car is '70 Cuda.
Corey - in Northern Indiana
Offline 4 speed fish
Re: Glove Box Finish - Flat or Semi Flat?
« Reply #1 on: November 09, 2009 - 12:55:23 PM »
Use sems trim black.It is a satin color not flat or semi.
Offline cwestra
« Reply #2 on: November 09, 2009 - 01:29:55 PM »
Is that the Landau Black #15013?
Offline tommyg29
« Reply #3 on: November 09, 2009 - 01:52:45 PM »
I used SEM Trim Black in the rattle can #39143.
Its on their website and ships by ground only.
Used it on the outside surface of my ashtray and steering column and matches very well.
Offline cwestra
« Reply #4 on: November 09, 2009 - 01:55:12 PM »
What would you consider the finish to be for that SEM trim black, semi-flat, semi-gloss, etc...?
Offline tommyg29
« Reply #5 on: November 09, 2009 - 01:57:13 PM »
I'm not an expert but I would say satin. It matches the existing.
Alaskan_TA
« Reply #6 on: November 09, 2009 - 05:49:59 PM »
1970 car? It was called "suede", see the white pages at this link;
http://www.hamtramck-historical.com/paintChipCharts/1970PaintChipCharts-01.shtml
Offline cwestra
« Reply #7 on: November 09, 2009 - 06:58:48 PM »
Interesting.  Wonder if suede is closer to flat or satin?  Do you know if the inside of the ash tray had a higher gloss content than the outside surface?
« Reply #8 on: November 09, 2009 - 09:01:27 PM »
it is closer to a satin / semi gloss black not flat black
Offline tommyg29
« Reply #9 on: November 09, 2009 - 10:27:07 PM »
ooops, sorry. I didnt realize 70 had a totally different color/paint from 71. Didnt mean to steer you in a wrong direction. :dunno:
« Last Edit: November 09, 2009 - 10:28:47 PM by tommyg29 »
Offline Aracer
« Reply #10 on: November 22, 2009 - 08:01:10 PM »
I guess Low Gloss "Hi-Heat Paint, Aervoe Brand, rattle can. The look is the same as a header tube, race car 'stuff' to look inflammable. It's a good match.
