496cid engine for sale
Author Topic: 496cid engine for sale  (Read 1216 times)
Offline challenger500
« on: November 10, 2009 - 01:37:13 AM »
For sale well kicking 496cid stroker engine. Details from the build + parts included. It's been build 2004, driven since ~1000 miles.
Took it one day to track with 7 passes, 11.9 /120mph with street tires and no power shifting. Otherwise not that much beaten...
Engine is still in the car so it can be seen in live if desired. Engine is located in San Jose, CA. Asking price for the engine is 6500$/ obo (need to make some room for new supercharged engine)
More pics can be taken and I'll send per request, these are from build-up phase and not complete as such.
You can contact me on my cell 650-450-1718 or email at hasse.sinivaara@gmail.com
Engine block + rotating assy
-   -67 440 block, line honed, new cam bearings
-   4,36 bore, stress plate honed
-   Eagle 4.15 crank, mopar journals
-   Eagle H-beam rods (6,76”, chevy pin)
-   Clevite 77 tri-metal bearings
-   Ross Racing flat top pistons (0,990 pin)
-   C&A rings
-   Zero balanced assembly
-   Vindage tray
-   Custom wider oil pan
-   Milodon external oiling + Hi volume melling pump
-   Fluidampr
-   Edelbrock double roller chain
Camshaft:
-   Comp Cams 23-742-9(Three Bolt), 308R
o   http://www.compcams.com/Cam_Specs/CamDetails.aspx?csid=739&sb=0
o   262deg @ 0.050 lift, 0.575 valve lift, adv.dur. 308
o   Thrust button (roller bearing, custom)
-   Comp Cams lifters #829-16
-   Comp Cams pushrods, 3/8” 0.080” wall cro-moly
Heads
-   Edelbrock RPM aluminum (84cc chamber)
-   Intake/exhaust ports smoothed, intake port matched
-   Ferrea 5000 S/S valves, 2,14in /1.81ex
-   3 angle seat work
-   Comp Cams double springs #929-16, assembly height 1,84” (seat press 160lbs, open 440-450lbs)
-   Crower retainers with 10 degree locks
-   Crower spring seats
-   SCE .036" Copper head gasket
-   Mopar performance roller rocker arms
-   Mopar performance head covers
Intake
- Holley street dominator single plane, smoothed + port matched
Carb
- Holley 850cfm dp
- 4" K&N filter + mopar performance black cover
Cooling
-   Aluminum water pump neck
-   Aluminum hi vol pump
Ignition
-   MSD Pro Billet distributor
-   Custom accel 8.8 wires
-   Autolite plugs
available as well: Hays steel flywheel, 6-bolt (100$)
and  Hooker Competition headers 1 7/8” primary / 3” collector (100$)
« Last Edit: January 13, 2010 - 11:30:51 PM by challenger500 »
Dementia already from the year...mmmm ???
Re: 496cid engine in sale
« Reply #1 on: January 13, 2010 - 11:30:30 PM »
Up... nice engine for a good home  :sly:
