Author Topic: correct chassis paint  (Read 554 times)
Offline moparnut
    • My Photo's
« on: November 10, 2009 - 10:53:06 AM »
whats the correct chassis paint for the k member and rear end?
do they have a extra hard correct paint for rock chips ect?
thanks
2012 Subaru Forester
70 D100 Adventurer 383 pickup
06 Honda VTX1800S Spec 3
Re: correct chassis paint
« Reply #1 on: November 10, 2009 - 11:07:18 AM »
I'm going to use Krylon "Rust Tough" in matte black.  I've tried used a flat black and then spraying a gloss clear over it.  You end up with more of a matte finish but the Rust Tough matte black looks a lot nicer.
Some people like having those components powder coated since that stuff dries hard.  Eastwood sells a powdercoating kit for the DIY'er.
I've been using POR-15 for larger components.  That product also dries hard.  You have to topcoat the POR though since it is not UV safe.
On a side note...if you are planning on simulating the cosmoline coating on the LCA's try spraying them with Seymore's Stainless Steel paint first and then spray them with Krylon Battery Protector.  It dries hard like a paint and looks very close to cosmoline.
Offline ksierens
    • 70 Challenger Resurrection
« Reply #2 on: November 10, 2009 - 11:22:35 AM »
I used SEM trim black.  I like it because it has a satin finish and is available in quarts/gallons and spray cans for fast touchup.
Kurt - SE Michigan
« Reply #3 on: November 11, 2009 - 09:25:57 PM »
I have used Eastwoods Epoxy black chassis paint
