Author Topic: Upper Seat Belt Location  (Read 5818 times)
Offline Aussie Challenger
« on: November 11, 2009 - 07:15:22 AM »
  Just been told that I have to install a lap/sash belt instead of my retractable lap belts so I can register my Challenger in Australia.   :banghead:
  I haven't checked yet but where on an early '70 would the upper location be, in the roof or on the rear side panel? The car is in storage at the moment.
  Were the reinforced nuts installed into these panels at manufacture or will I have to make my own?
  Thanks in advance.   :cheers:
Offline HemiOrange70
Re: Upper Seat Belt Location
« Reply #1 on: November 11, 2009 - 08:56:06 AM »
There is a threaded hole on the roof just behind the front seat. You should be able to feel the hole through the headliner.  http://cgi.ebay.com/ebaymotors/1970-Dodge-Challenger-R-T-440_W0QQitemZ110455802161QQcmdZViewItemQQptZUS_Cars_Trucks?hash=item19b7adc931
this ebay auction has a pic at the bottom of a top belt...as does this one       http://cgi.ebay.com/ebaymotors/1970-DODGE-CALLENGER-R-T-HEMI-CLONE-2FAST-2FURIOUS-CAR_W0QQitemZ290367023785QQcmdZViewItemQQptZUS_Cars_Trucks?hash=item439b392aa9
« Last Edit: November 11, 2009 - 09:06:04 AM by HemiOrange70 »
Offline 73EStroker
« Reply #2 on: November 11, 2009 - 12:25:10 PM »
Dave, if you give me your email address I will send you an email that has pictures of where the top hole is. What I did was feel with my thumb then poked a sharpened steel wire through to 'feel' for the threads. No extra holes in the upholstery this way.
Barry
Barry (Salmon Arm)
Offline _Russ_
  • Not very family friendly!
  • Chk Chk Boom!
    • Show Me How To Live
« Reply #3 on: April 24, 2010 - 06:00:23 PM »
Dave ... how did you go about this?
Will be in the same situation soon enough, and would love to get some ideas on how you (or any other Aussies) tackled an ADR compliant lap/sash belt install. I've done a search, but most, if not all the pics are no longer available.
Offline _Russ_
  • Chk Chk Boom!
« Reply #4 on: April 24, 2010 - 06:02:25 PM »
Ah ... just found your thread over on Mopar Market :) Good stuff!
Offline RUSTY Cuda
  • One big step foward!
« Reply #5 on: April 24, 2010 - 08:02:50 PM »
Mines a 73 I hope there the same, seat belt bolt is hard to see but I marked it for you. hope it helps ,Rich.
« Reply #6 on: April 25, 2010 - 01:27:30 AM »
Thanks for the info and pic's, I didn't want to mount it from the roof unless I have to, I am trying to negotiate with my engineer who has to sign off on it.
I am going to try and mount a retractable belt from the lower panel behind the front door so the belt is not in the way of rear seat passengers when they get in & out plus the belt mounted from the roof would flap around and drive me crazy.   :cheers:
Thanks RUSTY Cuda for those pic's.   :2thumbs:
Offline swede-cuda
« Reply #7 on: April 25, 2010 - 01:56:56 PM »
 :swaying:there should be 2 hooks mounted over the door window in the roof,that the belt presses up behind when not in use to keep it from flapping around.i only use the lap belt,so far anyway,and the hooks kepp the shoulder belt tucked away nicely.sorry no pics
Alaskan_TA
« Reply #8 on: April 25, 2010 - 03:43:05 PM »
« Reply #9 on: April 25, 2010 - 08:41:59 PM »
Thanks Barry for that pic, the belt does fit neatly up there. My problem is when belt is in use and driving along the belt flaps around neck & shoulders and it has annoyed me in other cars fitted that way. I wanted to keep my original retractable lap belts but Australian rules make us fit lap/sash.
Offline RUSTY Cuda
« Reply #10 on: April 25, 2010 - 09:00:10 PM »
Maybe go with the 74 set up, that has em mounted in the guarter inner panels, not sure how they get over your shoulder, been 30 years or so since I used em, if you need I can check it out in my 74 & shoot some pics. Rich.
« Reply #11 on: April 25, 2010 - 09:24:19 PM »
RUSTY Cuda that is basically where I intend to mount them, any pictures would be appreciated, the more I can show the engineer the more likely he will allow me to do it my way.   :cheers:
Offline RUSTY Cuda
« Reply #12 on: April 26, 2010 - 08:55:43 PM »
I'll try & shoot some pics tomorrow, if the rain stops I'm gonna work on the 73 a bit, I'll check out the belts for you then. Rich.
Offline RUSTY Cuda
« Reply #13 on: April 27, 2010 - 07:26:54 PM »
K, this may be worse, 2 units on the floor & still using that bolt up at the roof, excuse the condition of the car, but it's my next project so still quite a mess!  :-[
Offline _Russ_
  • Chk Chk Boom!
« Reply #14 on: April 27, 2010 - 09:27:09 PM »
I think I like nqkjw's idea over on MoparMartket.
You have to put a hole in your trims, but it's a lot cleaner look, and out of the way.
