Author Topic: 4-speed dripping oil  (Read 968 times)
Offline barryv
« on: November 12, 2009 - 08:42:07 PM »
hi,can anyone tell me what is causing as well as how  to repair oil that is leaking at the reverse lever connection on the transmission,thanks
Re: 4-speed dripping oil
« Reply #1 on: November 12, 2009 - 09:45:20 PM »
There is an 'o' ring on the shaft. Unfortunately you have to remove the guts of the tranny to replace it.  :-\
« Reply #2 on: November 13, 2009 - 12:17:39 AM »
not nessisarily , the stock 4 speeds use an O ring on the shaft & every single piece of the tranny has to removed to replace it , but if it is a later OD version the O ring can be replaced by removing the lever & the nylon ring & the O ring is right behind the nylon
Offline barryv
« Reply #3 on: November 13, 2009 - 07:45:26 AM »
its a regular tranny.does the whole tranny literally have to come apart to replace oring.is there any sealants that may work, thanks
Offline Changin Gears
« Reply #4 on: November 13, 2009 - 08:10:57 AM »
Well not the whole trans, but 98% of it.
« Reply #5 on: November 13, 2009 - 11:29:48 AM »
well it is basicall the first piece put into the tranny case so it will be the last piece to remove , you can leave all the gears on the main shaft though
Offline barryv
« Reply #6 on: November 13, 2009 - 08:51:04 PM »
maybe i dont understand or i didnt explain leak propperly. its dripping were the reverse lever on the side cover that has bolts and a gasket.does it still have to be taken all apart. i just want to make sure i understand,thanks again
« Reply #7 on: November 13, 2009 - 08:53:17 PM »
The reverse lever is on the bottom of the side of the trans.  It is not on the side cover, the 2 levers on the side cover are 1/2 and 3/4.
« Reply #8 on: November 13, 2009 - 11:07:04 PM »
Just to add to Changin Gears post, if it is leaking from the 1/2, 3/4, you don't have to tear down the whole tranny, just the cover.
Offline fantum
« Reply #9 on: November 14, 2009 - 10:23:51 PM »
I Think this might help ............  :useless:
