Author Topic: Running Engine with Valve Covers Off  (Read 798 times)
Offline cwestra
« on: November 13, 2009 - 10:57:43 AM »
How much oil would get flung around outside the engine if I were to idle my engine with the valve covers removed?
Corey - in Northern Indiana
wagesofsin
Re: Running Engine with Valve Covers Off
« Reply #1 on: November 13, 2009 - 11:02:46 AM »
well , if ya dont mind it getting on the exhaust and smokin you out.... hahaha.  in reality though , for a very short time , it wouldnt be that bad , just have a rag handy .
« Reply #2 on: November 13, 2009 - 11:31:46 AM »
use a peice of 5-6" wide cardboard along the lower edge of the head to catch the splash off the rockers , it is nowhere nears as bad as any engine that oils through the pushrods with the oil holes pointed straight up though
« Reply #3 on: November 13, 2009 - 06:48:33 PM »
I don't know how long you plan to idle, but hopefully not at high speed.     :22yikes:
Offline bb71challenger
« Reply #4 on: November 13, 2009 - 06:52:36 PM »
When I changed the top end on my engine I had heard that there might be an issue with getting the new rocker shafts right, keeping the rockers from getting oil. I ran the engine for a short time making sure that the rockers were all getting oil. The cardboard trick sounds useful too.
*Brett*
« Reply #5 on: November 13, 2009 - 06:56:20 PM »
I've heard of some that have taken old valve covers and cut the tops off.
I haven't done it so I can't warrant it's effectiveness.
Offline CHL2T
  • Handle it, man!
« Reply #6 on: November 14, 2009 - 11:10:56 AM »
Now there's an idea :2thumbs:
Offline FJ5_440
  • Wisconsin
« Reply #7 on: November 14, 2009 - 12:05:53 PM »
Years ago I had a set of valve covers that I cut down for just this purpose -- they were the stock ones off of my 70 440.  Now they would be worth several times what the chrome ones I put on the car are worth.  You never know what will become valuable. :dunno:
** Shane **
Offline 422STROKER
  • Member Since 6/3/06
« Reply #8 on: November 16, 2009 - 07:18:51 PM »
I had mine off when I was fine tuning the Preload on my motor.  Got messy after about thirty seconds....  But worked well.
Tom :cooldancing:
Tom
Offline dodge freak 2
« Reply #9 on: November 16, 2009 - 07:43:27 PM »
Just get the cheapest set of covers on ebay and cut the tops off. I like using studs instead bolts to hold the valve covers down. With studs it be very easy to drop those cut covers on..the studs hold the gasket down too so the cover comes off but the gasket stays on the head. I am using Mr Gasket utla seal--not the reusable gaskets yet am able to reuse them with no leaks.
Offline cwestra
« Reply #10 on: November 16, 2009 - 07:50:02 PM »
Thanks for all the input.
