Author Topic: Wanted-rear sway bar frame bracket  (Read 959 times)
Offline JayBee
« on: November 14, 2009 - 09:46:43 AM »
As you can see one of mine has a rust hole that will only get bigger once it's sandblasted. Anyone?
John
1970 Barracuda convertible
2014 Toyota Avalon
Re: Wanted-rear sway bar frame bracket
« Reply #1 on: November 14, 2009 - 01:03:30 PM »
If you can't find one, Send it to me and I'll repair it for you. No charge, just shipping.
Offline coupman35
  • It going to be FUN
« Reply #2 on: November 14, 2009 - 01:28:42 PM »
I fix mind by using 2 piece of 1 1/2 angle steel  weldem together it work great ans just as stron .You have to use the old top part and weld that back.
1941 Dodge truck 340cu
1935 ford 3window coupe 327cu
1965 Acadian Beaumont Convertible 283cu
1973 Challenger 318cu
Offline JayBee
« Reply #3 on: November 14, 2009 - 02:33:31 PM »
Thanks for the replies guys. I'll keep your options in mind but ideally I'd like to hold out for a bit longer and try to get one. There's got to be someone that's modified their rear sway bar to new stuff and has their old brackets laying around. Thanks again.
John
2014 Toyota Avalon
« Reply #4 on: November 14, 2009 - 09:53:08 PM »
Whatever works best for you.
If you don't find one, I'll be around if you need me to fix it.
I also have a sand blaster ready to go. So if did repair it, I'd make it look like new. So if you do decide, probably it's best you send both so I can blast em both then repair the one. Then send em back.
Offline the_engineers
« Reply #5 on: November 16, 2009 - 12:08:45 PM »
Still looking?  I may have one.  I'll snap a pic when I get home.
Brooks
1971 'Cuda 360
2004 Infiniti G35 6-spd Coupe
Offline JayBee
« Reply #6 on: November 16, 2009 - 05:27:15 PM »
Yes I am....thanks
John
2014 Toyota Avalon
« Reply #7 on: November 16, 2009 - 10:41:52 PM »
Let me know if you want it.
Brooks
1971 'Cuda 360
Offline JayBee
« Reply #8 on: November 17, 2009 - 04:39:47 PM »
Brooks, PM sent
John
John
2014 Toyota Avalon
