Author Topic: What makes the reverse lights come on?  (Read 4816 times)
« on: November 14, 2009 - 11:08:43 AM »
Hi Gang! :wave:
I have a 70 Challenger that was a column shift . I am now in the middle of the floor shift conversion ( SLAP STICK). I have all the linkage to make the shifter work, but I don't have the "lockout" linkage that attaches to the steering column arm.( under the hood , close to firewall)
Do I need that linkage for the reverse lights to work or is it in the neutral safety switch on the tranny?
Thanks Brad
Offline ksierens
    • 70 Challenger Resurrection
Re: What makes the reverse lights come on?
« Reply #1 on: November 14, 2009 - 11:21:38 AM »
There is a switch in the trans for the reverse light, though without the lockout, you may have to turn the column to get your key out sometimes.
Kurt - SE Michigan
« Reply #2 on: November 14, 2009 - 01:14:51 PM »
the neutral safety switch is the` reverse light switch as well
« Reply #3 on: November 14, 2009 - 02:43:34 PM »
Hi Gang! :wave:
Thanks Brad
I converted my car from a column shift as well and never bothered with the 'lock-out' linkage. IMO it's best left out anyway. I've never had a problem removing my key... :dunno:
Offline ksierens
« Reply #4 on: November 14, 2009 - 03:38:36 PM »
Mine is a 70 and came with a 4 speed.  The guy I bought it from took out the lock out linkage and  for me at least, if the cover around the base of the column would get turned, the key would not come out.  No big deal, just twist it and Bob's your Uncle!
Kurt - SE Michigan
« Reply #5 on: November 14, 2009 - 03:57:55 PM »
THANKS GUYS!
Next question, When I go to put on the linkage from the tranny arm to the shifter      ( under the car) The neutral switch is in the way. I know there is 2 switches one long one short. The one that is in there now measuring just the hex part is about 3/4" long. Is this the long one? If it is can I just switch to the shorter one?
« Reply #6 on: November 14, 2009 - 08:31:15 PM »
I didn't know there were two sizes of nss switches! Learn something here every day! Mine measures about 3/4" as well but I can't tell you if it's the long or short one. I can tell you that it didn't interfere with linkage, it was close though. Is it possible the bracket that locates the bottom of the rod that passes through the floor (bolted to the tranny case) is a little bent? :popcorn:
« Reply #7 on: November 14, 2009 - 08:51:17 PM »
I "think" I found the problem the shifter arm on the tranny (727) might not be correct for a slap stick set up. Would you know? :dunno: I think it's not long enough and it needs to drop down some?
« Reply #8 on: November 14, 2009 - 11:41:06 PM »
I'm on a midnight shift at the moment, but when I get home tomorrow I'll take a pic of the lever on my tranny. The tranny isn't in the car so I shouldn't have too much trouble getting a clear pic. :picture:
Offline oldkimmer
« Reply #9 on: November 23, 2009 - 03:00:05 AM »
...............U need a straight 1.................i have lots, send me ur addy , ill send u 1 out...........kim..... :canada:
The beast has been unleashed........Thems the hazzards..........Unleash the beast......
« Reply #10 on: November 23, 2009 - 07:27:58 AM »
Wow thanks! I just bought one off E-bay last week. I'm waiting for it in the mail, but thanks! If that doesn't work out I'll take you up on that! :2thumbs:
http://cgi.ebay.ca/ws/eBayISAPI.dll?ViewItem&item=360206159585&ssPageName=STRK:MEWAX:IT
Offline 72cudamaan
« Reply #11 on: November 26, 2009 - 12:10:43 PM »
Well putting the trans in reverse makes the reverse lights come on silly. :roflsmiley: :roflsmiley: :roflsmiley: Sorry, couldn't help myself.
If I cant fix it, it's broke
Andy  (phukker whither)
Offline TreeFrog
    • TreeFrog
« Reply #12 on: March 08, 2010 - 03:22:31 PM »
Geeze, and I wanted so badly to say ... "It's Magic"
87 Dodge Ram     318 Blue
88 Dodge Ram     360 Grey (+)
