It has been a long time since I have done it, but you should unplug the steering column harness. There are two nuts on studs right near where the column enters the dash, remove those nuts & you can drop the column down & pull it back.
If you have not done it yet, you will need to disconect any linkage connected to the engine bay side of the column also.
