Author Topic: Hurst Super Shifter  (Read 2128 times)
Offline Cruzin
  • I love YaBB 1 Gold!
Hurst Super Shifter
« on: November 15, 2009 - 02:45:43 PM »
Hurst Super Shifter.  Reverse lock out, works great in place of stock 4 spd. shifter. Includes Hurst mounting plate.  $100 520-444-0547
Offline cudasteve72
Re: Hurst Super Shifter
« Reply #1 on: November 15, 2009 - 03:37:00 PM »
can you put a pistol grip on with the reverse lock out?
1972 Cuda Custom 70 clone  416 stroker 481/531 hp/
2006 Grand Cherokee SRT8 (daily)
1970 Challenger convertible 340 (Dad's)
1967 Dart gt slant six all original 40,000 miles driver but needs restoration (Brother's)
2011 Jeep Grand Cherokee (wife's)
Offline Changin Gears
« Reply #2 on: November 15, 2009 - 04:06:13 PM »
Yes you can, as long as its the bolt on version.
Offline 73Chally
« Reply #3 on: November 16, 2009 - 04:37:11 PM »
Does this mount in the stock location, and are any mods needed to the tunnel?  Also, would this work with a console, or would the console have to come out?
« Reply #4 on: November 17, 2009 - 09:54:59 PM »
I have a Super Shifter in my car and the tunnel needs to be modified, but only the hole in the top where the shifter is. The super shifter mounts higher and further off centre in order to have the 1/2, 3/4 shift rods straight. I have a console mounted with mine but the side of the console was cut out to accommodate the shifter. I think it shifts far better than the stock shifter did.
Offline Cruzin
« Reply #5 on: November 18, 2009 - 11:23:09 AM »
Using the factory shifter rods, no modification is necessary.  I used this shifter with the factory counsel.  I believe the individual who modified his did so due to using the ram-rod or straight shifter rods which repositions the location of the shifter.  Again no modifications are necessary if using the factory linkage.
