Author Topic: 3rd gear slipping in 904  (Read 9482 times)
Re: 3rd gear slipping in 904
« Reply #15 on: November 18, 2009 - 09:16:04 AM »
http://www.cuda-challenger.com/cc/index.php?topic=27855.0
Even though it starts off saying 727 rebuild, I find out shortly that it's a 904.  I have most of the pictures saved on my HD if you need reference to any of them.....looks like most got deleted by accident.
Put the pics on http://photobucket.com/ replace the uploads with links & they will not be effected by server cleanings or moves.
Offline RDF
  • The pain that greets me is the stick that beats me
« Reply #16 on: November 19, 2009 - 07:41:00 AM »
yepper, pics are gone.
id love to get a set.
lemme see what I can do....PM me an email that I can send pictures to for now, until I update the thread.
  yeah but there are prob. 50+ pics..... :faint:
Bob
1973 'Cuda
If we never drown we'll never know how well it tastes....So tell me how it tastes and I'll know just how well you drowned.
My build:
http://www.cuda-challenger.com/cc/index.php?topic=45749.0
Offline QuartermileCuda
  • Shot of it in its Final Assembly
« Reply #17 on: November 19, 2009 - 10:23:54 AM »
Hey guys thanks a lot for all of the ideas. Ill drop my trans this winter and find out whats up.
71 340-6 AAR 'Cuda Concept.
(Was a 73 Barracuda)
69 Dodge Charger 383 4 speed. T5 Copper Needing Resto!
340/416 Stroker, 904 w/ Gearvendors gear splitter, 3:91 Posi.
Cant wait to see how fast she'll move. ;)
« Reply #18 on: July 04, 2010 - 12:04:04 PM »
Hey guys. Sorry to start posting on the old one but I didnt want to start up a new thread. lol. But anyway I tackled my transmission for the second time after driving it home with the same problem. This time I pulled my input shaft back out and checked both clutch packs. All the friction disks and clutches looked alright so I left them alone. But a friend at school told me that it is a good chance that it was the seals in the rear clutch pack and that if they were slightly worn at all it could cause my problem. So I replaced them. But I think I did it wrong because now the car only works in reverse. lol. So I think I put the seals in backwards and thats why I have no forward gears. So its all coming apart again and I'm taking a closer look at the book this time. I was just wondering if this could really be my fix to the original problem or if I should look elsewhere?
Offline ShelbyDogg
« Reply #19 on: July 04, 2010 - 06:58:15 PM »
When you pulled the clutch pack to look at the clutches and steels, did you go one step farther and pull the piston out and check it's seals?  You were already there and just had to pull a couple more things off to get the piston out.
Also, you can pressurize the case holes with air pressure to hear the clutch packs compress before you put it back in the car.
Get a service manual. It is all in there.
« Reply #20 on: July 05, 2010 - 03:24:04 AM »
I messed with that piston this time when I got into it again. I think those are the seals that I might have put in wrong... Ill Pressure check them before and after I pull them apart to see if it makes a difference. Service Manuel wise all I have a 727 book. I hope its similar enough to the 904 where everything should be the same.
Offline 6packCuda
« Reply #21 on: July 05, 2010 - 09:58:35 AM »
The lip of the seals should point towards the bottom of the piston.
Offline tactransman
« Reply #22 on: July 06, 2010 - 11:18:42 AM »
Here are some 727 pics,904 would be the same.
Terry-tactransman
Union, Mo.
« Reply #23 on: July 07, 2010 - 11:25:20 PM »
Flipped the Seal around and now everything works! Car moves forwards and Backwards! Still hasnt fixed my original problem though. I think I am just going to live with it till I get a 727 or do a 5.7 Swap. Thanks for all the Help and Pictures!
