Swapped to another mastercylinder (same type) which I first had benchbleeded but the result is the same.
No oil coming out of rear bleeders when pressing pedal down, impossible to build up pressure with bleeders
closed. Took the first mc and benchbleeded it, this time when you press the cylinder it squirts oil/air thru
the holes in the reservoar, or out of the holes. That didn't happen before with this one and not with the other one either. The oil passing the bleederhose is airfree. Is that normal?
Per
