Well, I have the trunk floor pretty much striped to bare metal.
WHat remains is the wheel tubs and the section right behind teh rear seat, as well as the inners of the rear fenders and the vent tube on the right.
Used a wire cup and drill, as well as razor blades to scrape. Wasnt TOO horrible.
Problem is, not sure I can get what is left off without major hassle.
I may try a test spot and spray over top the splatter paint and see what it does.....
That said, what would be good for wiping down the bare metal and the splatter painted stuff to clean it up prior to paint?
Cannot use the spray panel cleaner I have as it requires being rinsed by water....cant happen here.
I think that I will need to clear coat what is left of the splatter paint first.....my guess, by reading stuff on the wed, is that they shot my trynk with spray can splatter paint after all since when it gets wet it dissolves. APparantly the spray can stuff can/must be clear coated to protect it.
So I guess any clear coat will work.
Then, once that is done, go back and primer everything, then spray the body color on it?
Or maybe just priming it with regualr primer will be enough of a sealer?
