Author Topic: 1970 cuda quarter trim  (Read 2270 times)
Offline E-Body Products
  • E-Body Products
    • E-BODY PRODUCTS
« on: November 19, 2009 - 10:35:35 PM »
I am needing the hole locations for the door top trim for the quarter window area for my 70 cuda.  My doors already have the holes, but the quarter tops need the holes as well.
Thanks,
Daniel
www.ebodyproducts.com
dj1965@ebodyproducts.com
606-481-0213
Offline 67vertman
  • Member since 9-23-2005
Re: 1970 cuda quarter trim
« Reply #1 on: November 20, 2009 - 08:56:18 PM »
Daniel,
Can you post a picture of your door tops?  I need both locations, door and quater windows.  Hole size and something showing the distance between holes would be great.  My car didn't come with this molding so I am starting from scatch.
Thanks.
  • E-Body Products
    • E-BODY PRODUCTS
« Reply #2 on: November 20, 2009 - 09:13:09 PM »
I will try to get the pictures of the hole locations from the doors on Saturday.  We both will still need the quarter window hole locations.
 :wave:
  • E-Body Products
    • E-BODY PRODUCTS
« Reply #3 on: November 22, 2009 - 09:24:21 PM »
Here are the door hole locations from front of the door to back of the door.  I also went off of the edge of the front top of the door at the form line.  Dimensions are in inches.
7/8
3 7/8
11 1/8
18 1/2
24 7/8
31 1/8
38
46
All holes are offset from the inside by 3/8".  If done correctly, the very last hole at the rear of the door should also be 3/8" form the end.  So it would be located 3/8 from end and 3/8 from inside edge of door.
Hope this helps...  Now, does anyone have the hole locations for the quarter windows for a 70 cuda?  I know the 70 cars are different from the 71 cars as well.  Please help...
Thanks,
« Last Edit: November 22, 2009 - 09:29:39 PM by E-Body Products »
Offline 67vertman
« Reply #4 on: November 22, 2009 - 10:58:54 PM »
Thanks Daniel,  That is perfect info.   :2thumbs:
Opps, what size are the holes?  :clueless:
Now I need to drill some holes.  :clapping:
« Last Edit: November 22, 2009 - 11:06:17 PM by 67vertman »
  • E-Body Products
    • E-BODY PRODUCTS
« Reply #5 on: November 22, 2009 - 11:46:14 PM »
Dag Nabbit...  :swear: I forgot.
I will get the hole diameter for you on Monday. I will be back in the shop.
  • E-Body Products
    • E-BODY PRODUCTS
« Reply #6 on: November 23, 2009 - 11:00:11 PM »
The correct hole size is 1/4".
Please, I need the quarter window trim hole locations.
Offline Canadian Cuda
« Reply #7 on: November 24, 2009 - 01:39:53 AM »
i'll try to grab one for you tommorrow if not the next day
Geoff
70 Cuda 440-4, auto, 8 3/4 sure-grip
Offline 67vertman
« Reply #8 on: November 24, 2009 - 08:35:56 PM »
Thanks Daniel......1/4 inch it is.
« Reply #9 on: November 25, 2009 - 08:13:30 PM »
here ya go. these ar original as i know. measurement from farthest forward corner on inside edge. going from left to right.
hole 1= 1 1/4"
hole 2= 2 1/4"
hole 3= 4 1/4"
hole 4= 9 1/4"
hole 1,2,4 all 3/8" from inner edge
hole 3 is 1/4" from inner edge
these are  somewhat rough measurements but cosidering there was up to a 1/8" diffrence on each side of the car i imagine it's not a huge deal.
Geoff
  • E-Body Products
    • E-BODY PRODUCTS
« Reply #10 on: November 25, 2009 - 11:15:31 PM »
I wonder why hole #3 is not in-line with the other 4 holes?  Also, is there a hole on the front of the door jamb?  I was thinking that the 70 only trim wrapped over the front.  Is this the case?
Thanks...
Offline 67vertman
« Reply #11 on: November 25, 2009 - 11:49:11 PM »
Thanks...
I wonder why hole #3 is not in-line with the other 4 holes?   I too wonder why this hole is different.... :clueless:
Also, is there a hole on the front of the door jamb?  Thta is correct, there is a mount hardware that goes there.  I can get a picture of the trim peice this weekend.  My trim came with these peices.
« Reply #12 on: November 26, 2009 - 12:14:28 AM »
 i don't know about the 3rd hole they were the same on bothsides of the car :dunno: i didn't open the door so i'll take a look
Geoff
« Reply #13 on: November 26, 2009 - 06:29:33 PM »
well my is a real 70 BS23 cuda and it has no holeinside. and the trim i have has no tab. maybe it was an early 70 thing :dunno:
Geoff
  • E-Body Products
    • E-BODY PRODUCTS
« Reply #14 on: November 26, 2009 - 06:59:30 PM »
 :clueless:
Any second opinions.  I have learned to never say never when it comes to mopars.
Thanks,
Daniel
