Author Topic: Anyone ever installed this set?  (Read 2827 times)
« on: November 20, 2009 - 03:42:39 PM »
What all is involved?  Im getting a tach rebuild kit and wanting to get my clock working to, I guess I need these. How tuff is it to install? I know to remove the dash yadda yadda, after it's out.  Do I intall like a stripe kit with water n soap?
http://cgi.ebay.com/ebaymotors/1970-74-Cuda-or-Challenger-Rally-gauge-decals_W0QQcmdZViewItemQQhashZitem2a01d089a9QQitemZ180419070377QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
Offline Killer_Mopar
Re: Anyone ever installed this set?
« Reply #1 on: November 20, 2009 - 03:48:41 PM »
 :popcorn: I would like to know as well.....
Offline 72hemi
  • MEMBER SINCE JANUARY 2006
« Reply #2 on: November 20, 2009 - 04:45:33 PM »
They were easy to install. Just like stickers really. On the tach speedo and clock you have to remove the needles.
« Last Edit: November 20, 2009 - 04:49:47 PM by 72hemi »
1996 Dodge Viper GTS Coupe
« Reply #3 on: November 20, 2009 - 04:48:38 PM »
tell me about needle removal,  and lining it back up
Offline 72hemi
« Reply #4 on: November 20, 2009 - 04:51:46 PM »
The needle removal wasn't that hard. The set of decals I ordered came with instructions on how to remove the needles and reinstall them. As I recall (I did this 2 years ago) the speedo was the only tricky needle to remove and reinstall, but basically I think you grab the gauge shaft with needle nose pliers and then just pull off the needle.
Offline quapman
    • Auto-Grip on Facebook
« Reply #5 on: November 20, 2009 - 05:31:18 PM »
Do I install like a stripe kit with water n soap?
That's how I do it. I remove the needles by holding the mechanism inside the gauge (gauges out, of course) and twisting/lifting the needle, fingernails under the center. Reverse the process for re-install. (Twist/push) Just pull with fingernails for the clock second hand.
Offline miketyler
    • www.miketyler.net
« Reply #6 on: November 21, 2009 - 08:19:19 PM »
Some tach or speedo needles can be tough. Handle with care. I put the white faced decals on mine a few years back. Still look great!
72' Cuda restomod
70 Mustang Mach 1
01' Honda 1100 Shadow Sabre
96' Seadoo Challenger
« Reply #7 on: November 21, 2009 - 09:40:48 PM »
Do the needles have a guide line to install them back in a certain place?  Like a notch?  that's actually what I'm wondering about, is getting the needles back on in the same place.
Offline coupman35
  • It going to be FUN
« Reply #8 on: November 21, 2009 - 10:58:47 PM »
I just did my dash and dint take the needle off it was not that hard  to do.I have a spare set the only thin missing in it is the tack decal for 7000rpm i have the one for 8000rpm.
1941 Dodge truck 340cu
1935 ford 3window coupe 327cu
1965 Acadian Beaumont Convertible 283cu
1973 Challenger 318cu
Offline quapman
« Reply #9 on: November 22, 2009 - 07:52:10 AM »
Nope, no notch or sweet spot. I just line them up with the "0". They are a very thin tube which fits onto a pin. Once seated, you'll still be able to twist into place. When you have one off, it will be pretty clear.
Offline the_engineers
« Reply #10 on: November 23, 2009 - 11:35:33 PM »
So how do you know your speedo and tach are correctly calibrated afterwards?
Brooks
1971 'Cuda 360
2004 Infiniti G35 6-spd Coupe
Offline kmyles
« Reply #11 on: November 24, 2009 - 01:49:22 PM »
 :popcorn:
_________
Kevin
Mopar Lover....Cuda's....Challengers Rule!!!!
- 1951 Dodge - 2 door hardtop (Sold!!)
- 1971 Dodge Challenger
- 2012 Dodge Challenger Yellowjacket
Hard to believe what 20 years will do!!!!
Offline quapman
« Reply #12 on: November 24, 2009 - 05:09:45 PM »
Well, I suppose they're as accurate as they were before refacing.
« Reply #13 on: November 24, 2009 - 08:13:09 PM »
Let me re-phrase.  How do you know that the needle is really pointing at the right number?  A slight turn of the speedo needle and all the sudden you're doing 10-15 mph more than the gauge says.  Funny until you get busted doing 40 in a 25.
Brooks
1971 'Cuda 360
Offline quapman
« Reply #14 on: November 24, 2009 - 09:34:18 PM »
The tach kits usually come with instructions for calibration, but this obviously doesn't help with speedo certification. I don't know of a way to get it done on the bench.
I think the better known gauge rebuilders can offer this service. They might have ads here or maybe Wade can do a site search for us...... there must have been several threads on this topic.
Mr. Bullitt....??
If you're asking "How do I keep my needle from twisting past its correct point at high speed?"  I don't know other than seating it firmly and doing a bounce test.
