On the driver's side front of the block, right under the deck (head gasket surface) is a flat pad with stmapings that will tell you what it came in, from where, and when. If the other numbers end in "71" the block is cast in 71. You need to know if it's a forged crank 71. or cast crank '72 model year assembly. The stamping will tell you that.
