Author Topic: Ratty R/T Project, Almost done!  (Read 1375 times)
Offline CHL2T
  • Handle it, man!
« on: November 22, 2009 - 02:56:35 AM »
After driving the Cuda last spring/ summer, I felt it was time to make the Challenger the one I always wanted.
It started by finding (on CL) the original go wing, in good shape but needing a good scraping and paint. At that point I figured it was time for the front disc swap (which is described in another thread) After installing the wing, I just couldnt stand the butt without the dual exhaust. After a rough bidding war, I landed a used but straight original 70 dual exhaust valence. After winning the valence, I needed a set of tips to go with it and wouldn't you know it, a used set came up, and a couple days after the valence showed up, they were here.
 Once the ball started rolling it became clear that if the Ratty R/T was going to happen I was gonna need to get the R/T hood to go with the exhaust. Once again it's back to CL to find the hood that I had seen months before and wouldn't ya know it, there it was, complete with inserts, 340 emblems and front trim, all for less than a repro! Once installed, the petty blue just wasn't right, so ten cans of .97 home depot spray paint later, it's flat black with gloss black blackout.
After installing the aftermarket swaybar (also scored from CL) I "custom" bent the tail pipes on my Ram bumper :smilielol: and fitted the tips in the holes and are now ready for tacking.
Once I bleed the brakes, drill the rear sway bar link bracket holes, service the tranny and give it some new plugs and wires, pick up a set of trim rings tomorrow (CL once again!) I think it will be, for lack of a better word "done"
God willing, spring/ summer of '11 the Challenger will recieve the bodywork and paint it deserves.
Again, God willing, the Cuda's date with destiny is spring/ summer of '12
Spring/ summer of '10 the E's will be driven daily if possible while painting/ finishing the 69 Charger
I will post pics of the Ratty R/T when finished and as soon as it stops raining (hard to take pics in a crowded garage) :cheers:
Offline DAYLEY/CHALLENGER
Re: Ratty R/T Project, Almost done!
« Reply #1 on: November 22, 2009 - 10:01:09 AM »
Here you go......................
 :useless: :useless: :useless:
hahahahaha
Dave or David
« Reply #2 on: November 22, 2009 - 11:40:43 AM »
hahahahaha
:iagree:                :iagree:               :iagree:                   :iagree:                     :iagree:
Offline CHL2T
  • Handle it, man!
« Reply #3 on: November 22, 2009 - 01:56:17 PM »
As soon as the rain stops, I will take some serious pictures, as stated above, It's tough to take pictures in a crowded garage :2thumbs:
Offline dutch
« Reply #4 on: November 22, 2009 - 02:58:15 PM »
 :popcorn:
*** Bart ***
Offline CHL2T
  • Handle it, man!
« Reply #5 on: November 22, 2009 - 08:03:50 PM »
So for today, I picked up a set of trim rings and with some minor alterations and some serious beating with a chunk of 2x4, got them on. Then I went around the back and tacked in the used tips :2thumbs:
Still need to replace the rear brake hose, drill the frame for the addco and while I'm there, throw some rustoleum up under there to protect the underside for another twenty years. Still need to bleed the brakes, give er a tune up and tranny service, adjust front end ride height, tighten shock bolt, tighten LCA shaft bolt and finally the sway bar end links.
Progress pics can be found here http://s981.photobucket.com/albums/ae295/CHL2T/ enjoy!
« Reply #6 on: November 23, 2009 - 07:46:41 PM »
You got a lot of projects................Looking good........keep them comming................ :2thumbs:
Dave or David
Offline CHL2T
  • Handle it, man!
« Reply #7 on: December 01, 2009 - 12:55:30 AM »
Got all the front end stuff tightened up, brakes bled, rear sway bar fully attached and drivers window fixed
Took it out for s short ride to the gas station and besides being out of alignment seems to be close to being good. I think I need some new upper ball joints as I am hearing a slight clunk from the right side when applying the brakes. What really sucks about that is that I shoulda done the balls while I was in there, I'm gonna get it up in the air and give the front wheels a shake and see what's up.
Couple of pics for ya.
« Last Edit: December 01, 2009 - 01:07:20 AM by HANDM »
Offline CHL2T
  • Handle it, man!
« Reply #8 on: December 01, 2009 - 01:01:43 AM »
Here are some before pics
Offline Street_Challenged73
« Reply #9 on: December 01, 2009 - 01:50:27 AM »
Nice progress so far. :2thumbs:  The go-wing and bulged hood look much better than the flat hood w/o any wing. :cheers:
Offline Cuda Cody
  • Vancouver, WA
« Reply #10 on: December 01, 2009 - 01:58:57 AM »
Looks great!  I see a Washington State plate.... where you from in WA?
Offline CHL2T
  • Handle it, man!
« Reply #11 on: December 01, 2009 - 03:04:34 AM »
It was a toss up between a Ratty T/A clone or an Ratty R/T clone and I found the wing first so that forced the decision. Plus while going through some stuff, my wife found an original R/T badge which I promply restored and slapped on the car, then came the grille painting and stealing the R/T badge from the Charger, the hood, the brake/ torsion bar swap, sway bars and finally the exhaust and tips.
And to C O D Y, I'm in Mountlake Terrace :2thumbs:
