Author Topic: anyone have a small block 440?  (Read 13244 times)
Offline GreenFish
« on: November 23, 2009 - 12:20:11 PM »
Curious as to how the small block 440 motors are.  Does anyone have any experience with these. Looks pretty cool. Rated at 540hp and a small block. What do they normally rev to?  Is the RPM range high?
Offline Bearcuda
Re: anyone have a small block 440?
« Reply #1 on: November 23, 2009 - 12:31:01 PM »
Smallblock 440? derived from what?
1973 Cuda 440
1971 Javelin SST
Offline 72hemi
  • MEMBER SINCE JANUARY 2006
« Reply #2 on: November 23, 2009 - 12:46:49 PM »
Its 340 based, below is a link to the crate engine. It looks like a monster, but comes at a hefty price tag, list price $15k, bouchillon performance sells them for a little of $13k.
http://www.bouchillonperformance.com/P5153523.asp
1996 Dodge Viper GTS Coupe
Offline 6packCuda
« Reply #3 on: November 23, 2009 - 02:20:45 PM »
If you're going to spend that kind of money on a crate engine, you might as well get a Hemi.
Offline 72hemi
« Reply #4 on: November 23, 2009 - 02:26:50 PM »
What if you don't want the extra weight on the front end, or the expense of replacement parts down the road, or extra money on motor mounts, pulleys accesories, transmission etc. It's easy to say well thats the same as a hemi but there are people who prefer the small block. Personally while the hemi is really cool for the wow factor, I would rather have the small block and still be able to carve corners, and the cost of an all aluminum hemi is about double the price of this crate engine.
Offline 73EStroker
« Reply #5 on: November 23, 2009 - 11:15:00 PM »
Don't know about a small block that big. Think about those short rods vs piston size vs rod angle. Think about 454 Chev motors - they have terrible rod ratios and are famous for using oil. Go with the R3 block stroked out to 358 and make a screamer if you are going to spend that kind of money. Richard Petty was very competitive with that motor in a 73 charger for Nascar in years past. Or go with a 340 stroked to 416 on the torque side.
Just my 2 pennys worth
Barry (Salmon Arm)
Offline the_engineers
« Reply #6 on: November 23, 2009 - 11:28:37 PM »
The 416 and the 440 are using the same length stroke (4"), so what's the issue?  Petty used an X block which cannot support bores in excess of 4.07 safely...no better than a 340 and some early 360's.
Chrysler trusts the design enough to offer a crate Commando in this size.  Indy has kits (and motors) in both this size as well as 472".
This is very high on my list.
Brooks
1971 'Cuda 360
2004 Infiniti G35 6-spd Coupe
Offline bb71challenger
« Reply #7 on: November 24, 2009 - 12:08:09 AM »
I saw an advert for a 630 hp pump gas small block in a magazine about 6 months ago or more. It sounds like the perfect bullet to me. I am sure it has the beefy race block so it would be heavier than a regular small block but so what, I could learn to live with that. I love the neck snapping torque of a big block and the screaming rpm ability of a small block, this engine seems to have both. Too much coin for me but would be tons of fun.   :burnout:
*Brett*
Offline Ck[FIN]
  • Get real - Get Mopar
    • Small car club from Finland
« Reply #8 on: November 24, 2009 - 10:46:31 AM »
little bit offtopic but x-block can support 4.10" bores safely. More if sonic checked. And also they are bulletproof if compared to 340 or 360 production blocks. A lot thicker deck,main webbing and enough material to gain support from 4 bolt mains.
Offline GreenFish
« Reply #9 on: November 24, 2009 - 10:57:41 AM »
That's kinda where i'm going with this
Offline matt63
« Reply #10 on: November 24, 2009 - 12:18:13 PM »
There is a guy at the local track with a 466 (or thereabouts) small block stroker that runs very low 10s in an early Cuda.  It's different.
Matt in Edmonton
'68 Valiant
Offline 73EStroker
« Reply #11 on: November 24, 2009 - 02:20:49 PM »
The small block still has a short rod compared to big blocks. Rod angle will be horrible. And how do you bore out a small block that far (from 416 size to 440) without making the cylinder walls too thin? I have always read oin this site that Mopars do not handle a lot of bore size increase. It's nice to go fast but its a lot nicer to go fast and have longevity in the motor for those of us that do not have an open cheque book.
Barry (Salmon Arm)
« Reply #12 on: November 24, 2009 - 03:05:10 PM »
I figured they made the stroke bigger on the sb 440
Offline itsfred
« Reply #13 on: November 24, 2009 - 03:52:31 PM »
not a small block guy but i have a question. where is the point when cubic inches so overwhelm the heads that going any bigger is actually costing hp? what i am asking is how do those heads flow enough to make hp with that kind of displacement?
Offline 72hemi
« Reply #14 on: November 24, 2009 - 03:53:48 PM »
those heads out of the box flow more than a lot of big block heads.
http://www.bjrracing.com/commando_heads.htm
