Author Topic: How to clean the engine..??  (Read 966 times)
Offline cowboy
  • Denmark
    • CowboyCars.dk
« on: November 23, 2009 - 03:26:31 PM »
How do you guys clean up an old engine on the outside from a lot of oil, grease and sticky stuf..???
I'm not gonna tear it apart, it runs well, but want to clean it up and paint it ..
Re: How to clean the engine..??
« Reply #1 on: November 23, 2009 - 04:02:51 PM »
Clean the heavy stuff off with a putty knife and a wire brush.  Plug all of the openings and finish it off with engine degreaser and a power washer.  A wire wheel on a drill is a good idea if you have some old paint you want to remove.
« Reply #2 on: November 23, 2009 - 04:09:16 PM »
On this side of the pond we have something called "Gunk" that does a good job. It's a foamy spray that you hose off later. As burdar suggested, you will want to plug your carb with a rag so nothing gets down it.
Offline quapman
    • Auto-Grip on Facebook
« Reply #3 on: November 23, 2009 - 06:58:43 PM »
I use oven cleaner. Spray it on, let it soak for a while, scrub the extra grungy spots with a scotch-brite pad, spray off with a hose.
Wear some good rubber gloves. This stuff is nasty on human flesh!
Offline boydsdodge
  • Top end's unlimited....Aaaauuuuugghhhhh!!!!!!!!!!!
    • Boydsdodge
« Reply #4 on: November 23, 2009 - 07:09:30 PM »
I use oven cleaner and power washer, I also found this great product at the home depot that is for stripping decks/washing.
It comes in a 4 litre jug that is purple, I dont have the name right now its out in the shop but i just brush it on with gloves and glasses and let it sit for a while like 30 mins, then hit it with power washer.
Comes out great. It also says that is biodegradable, i dont think after the engine dirt it is but the chemical is. :woo:
Jackson from Toronto.
Offline Tonefiend
  • '70 Challenger
    • Ian A. Guitars
« Reply #5 on: November 23, 2009 - 08:57:35 PM »
Purple power?
I have heard good things about it, a friend cleaned a carb and it turnedout pretty nice.
I have used Gunk foamy engine bright with good results.  Spray it on. let it sit a few then spray it off with water.
« Reply #6 on: November 23, 2009 - 09:04:16 PM »
When I use gunk, I warm the engine up first. It really helps
Offline moparmaniac59
  • Drive it like ya stole it!
« Reply #7 on: November 23, 2009 - 09:39:34 PM »
Simple Green works well also. Then the power washer. It worked well on my engine compartment. I've also used oven cleaner. Just don't tell Al Gore!! :roflsmiley: :smilielol:
                                                Matt B.
Matt
Offline cowboy
  • Denmark
    • CowboyCars.dk
« Reply #8 on: November 26, 2009 - 05:46:32 AM »
Bougth some heavy duty stuf oven cleaner, - and a high pressure water thing (120 bar) - paid 200 bucks for it, and even got a free patio cleaner in the deal..  :rofl:
Easy job, - you guys are great to be around...   :thumbsup:
