Author Topic: Best 340 Mods for the money  (Read 4233 times)
Offline IndyCuda
« on: November 23, 2009 - 06:08:42 PM »
Any advice on a 340 setup for making HP. What would you guys do to a stock engine with 3K play with.....
Re: Best 340 Mods for the money
« Reply #1 on: November 23, 2009 - 06:13:13 PM »
Bigger cam, headers, aftermarket intake, bigger carb. Getting the heads ported would help too. That would all be less than 3K.    :2cents:
Offline 71chally416
    • The Streetwalker
Offline IndyCuda
« Reply #3 on: November 23, 2009 - 07:12:15 PM »
I was thinkng of a little bigger cam....mybe a Voodoo. So ported X heads w/some 2.02 valves? I was thinking of just slapping some Eddy RPM's on.....I have a holley six barrel already on and will be using TTI headers....
Offline The Cuda Guy
  • Support Our Troops
  • Pearl Harbor, HI
    • C-C.com
« Reply #4 on: November 23, 2009 - 09:32:49 PM »
If you already have the 6bl set up and have TTI headers here is what I would recommend:
Alum heads, ported with roller rockers
Roller Cam
Windage Tray
That would prob get your 3k spent.
Don
Member Since January 14, 2002
Offline Katfish
  • 70 Challenger
« Reply #5 on: November 23, 2009 - 09:41:35 PM »
http://www.compcams.com/Community/Articles/Details.asp?ID=-738676943
Good info, I wonder what the gain would be if you did all the mods with the exception of the headers?  Maybe only 20-25 down, still have 370?
I've never seen a header that lasts longer than 3-5yrs.  Can't bear to pay $500-$800 for that.
« Reply #6 on: November 23, 2009 - 10:25:16 PM »
Cam, Intake, Heads & exhaust is where the power is made , Porblem is there is no real value priced small block heads that result in big power gains unlike the big blocks , W2 or W5 will make excellent power but you will spend more then you budget on them .
 I have made more power with ported 308 head castings than the equialent X or J casting so I would recommend them & the VooDoo cam choice is excellent , use an RPM Air gap intake & a Proform 700 carb
Offline IndyCuda
« Reply #7 on: November 24, 2009 - 03:42:24 PM »
Would I be better off and happier with immediate HP gains putting the $ in a forged stroker kit and porting the current heads? I would hate to dump a bunch of money in aluminum heads and make big HP with a weak crank and rods. If so can you reccomend a good forged stroker kit 408-416....
Offline moper
« Reply #8 on: November 24, 2009 - 08:58:22 PM »
What is the rest of the car built up to? Sometimes more power is something that should come after gears and a shift kit. What dont you like about the car now?
« Reply #9 on: November 24, 2009 - 09:09:30 PM »
I would talk to Eric @ Muscle Motors in Lansing Mi for a stroker kit ,there are other god options as well
Offline hooD
  • detroit iron
  • Motor City Made Muscle
« Reply #10 on: November 24, 2009 - 09:29:51 PM »
That's not much life for a set of headers.  The headers on my car have been on since 1975.
Doesn't the stock 340's already have a windage tray from the  factory?
-Larry
member since AUG 2007
southeastern michigan usa
1973 'CUDA 340
original owner
37,117 miles
« Reply #11 on: November 24, 2009 - 09:34:37 PM »
340s had windage trays fromm the factory
Offline LAA66
« Reply #12 on: November 24, 2009 - 11:33:11 PM »
 Those power making goodies will only go as far as the stock rods can handle. :2cents:
Offline 440mike
« Reply #13 on: November 25, 2009 - 01:19:29 PM »
we did a 340 where i work that used the edlebock heads with a solid flat tapett comp cams camshaft, and 030 over pistons for 10:1 compression on pump gas.
the new edlebrock heads had a pocket port that i did working there, and the boss had me mill the heads slightly. he always gets me to take apart new heads anyways to check guides, springs, redo seats, etc.
it also had a single plain intake and holley 750 carb.
wow
it made 432hp at 5700 rpm on the dyno !
seems like a pretty good combo for basically a stock 340 with bolt ons like heads and a cam and intake !
how come guys dont just go get the edlebrock heads, get them checked and milled slightly, then change cam and intake ?
i think a guy could do the edelbrock heads, xtq comp cam, intake and carb for under the 3k, and probably get very close to that engine done where i work ?
« Last Edit: November 25, 2009 - 01:23:51 PM by 440mike »
« Reply #14 on: November 26, 2009 - 01:51:48 AM »
I guess my issue with the Eddy heads was that we pulled out about 6 heads & they all had major core shift , possibly they send all the junk to Canaduh though
