Author Topic: Ballist resister?  (Read 1632 times)
Offline Glennster
Ballist resister?
« on: November 23, 2009 - 11:22:21 PM »
My car '' WAS ''  a 1970 with a 318 and points ignition. I'm putting in a 340 with electronic ignition. My new motor has the electronic distributor, I also have the orange electronic box shown in the first picture and I have a wiring harness (from Mancini Racing) that should adapt my points stuff to the electronic stuff.
Thank you for your help!!!
  Will my original (pictured at the bottom) Ballist Resister work with the new stuff, OR, do I need the 4 prong Ballist Resister.
« Last Edit: November 23, 2009 - 11:24:59 PM by Glennster »
Offline the_engineers
Re: Ballist resister?
« Reply #1 on: November 24, 2009 - 12:20:56 AM »
Where is your ballast from?  It should be OK as long as it was designed for your coil.
Brooks
1971 'Cuda 360
2004 Infiniti G35 6-spd Coupe
Offline Glennster
« Reply #2 on: November 24, 2009 - 06:12:58 AM »
I'll look at some old pictures, hopefully they show what it was hooked to.......I don't remember.
Offline Glennster
« Reply #3 on: November 24, 2009 - 06:28:49 AM »
Here's how it was ORIGINALLY wired, does this help?
I can't figure out what it was wired to.
THANKS for any help!!!
Offline Katfish
  • 70 Challenger
« Reply #4 on: November 24, 2009 - 07:04:06 AM »
I don't think that's the ballast for the ignition.  Should be mounted seperately on firewall.  The wiper motor has a different non-ignition ballast on it.
« Last Edit: November 24, 2009 - 07:10:52 AM by Katfish »
Offline 71 DEPUTY
  • IF YOU CAN'T DODGE IT--RAM IT!
    • Cardomain
« Reply #5 on: November 24, 2009 - 09:43:48 AM »
« Reply #6 on: November 24, 2009 - 10:33:49 AM »
« Last Edit: November 24, 2009 - 10:39:24 AM by Bullitt- »
Offline Glennster
« Reply #7 on: November 24, 2009 - 11:51:53 AM »
I bought this yesterday at Advance Auto...... But there is nothing on it that tells which side 5 Ohm and which side is 1.2 Ohm....
Maybe I need the 2 pin Ballist, I'm awawy from the car, I'll get a look at it tonight....
THANKS again for all the input!!!
« Reply #8 on: November 24, 2009 - 01:07:14 PM »
Your ignition module has 4 pins, not 5 like the diagram shown. You would use the two prong ballast resistor in that case.
« Reply #9 on: November 24, 2009 - 06:33:09 PM »
You can still use the 4 prong ballast resistor you bought, just only hook up the 1.2 ohm side.
 :2thumbs:
« Last Edit: November 24, 2009 - 06:35:59 PM by dodj »
Offline Katfish
  • 70 Challenger
« Reply #10 on: November 24, 2009 - 07:37:54 PM »
I'd get the correct 2 pin ballast, looks much better.
« Reply #11 on: November 24, 2009 - 07:43:52 PM »
A multimeter will tell you which is which.
Brooks
1971 'Cuda 360
