Author Topic: 340 R3 BLOCK QUESTION  (Read 4430 times)
Offline MOPAR-or-NoCar73
« on: November 24, 2009 - 01:11:27 AM »
Hi everyone
    I was looking at the r3 blocks here, to check out the specs and such:
http://www.jimsautoparts.com/mopar_performance_blocks.htm
I am looking at this section:
SMALL BLOCK CAST IRON "R3" RACE ENGINE BLOCKS
I am new/still learning about engines, so it is not obvious to me.
My question is P5153478AB a race block too? It is under that section, but the others have race,r3 while this one has 340 replacement. I was wondering what was the difference in what makes the others race,r3 while this one is 340 replacement. Is this one not as strong as the others below?
Thanks
Offline 71chally416
    • The Streetwalker
Re: 340 R3 BLOCK QUESTION
« Reply #1 on: November 24, 2009 - 06:09:25 AM »
The chart in the center explains the difference in the blocks.  Some are rough bored, some are finish honed, some are 48* lifter bore and some are 59*.......
Offline Ck[FIN]
  • Get real - Get Mopar
    • Small car club from Finland
« Reply #2 on: November 24, 2009 - 10:42:07 AM »
I remember that 340 blocks have original 10bolt head fastening? And they accept stock style camshafts and bearings. R3 use special camshafts, 50mm bore in the block if i remember correctly.
Offline the_engineers
« Reply #3 on: November 24, 2009 - 07:41:22 PM »
If you're looking to do something with a semi-reasonable budget, you want the 340 Siamese Resto Block.  this will maintain your stock deck height (9.599"), stock valvetrain angle and stock oiling system.  Any deviation from this will involve extraordinarily expensive parts.
Brooks
1971 'Cuda 360
2004 Infiniti G35 6-spd Coupe
Offline 71chally416
    • The Streetwalker
« Reply #4 on: November 25, 2009 - 06:30:23 PM »
Here's an interesting article on a race block based 340 engine.
http://www.moparmusclemagazine.com/techarticles/engine/mopp_0310_340_engine_600_hp/index.html
« Reply #5 on: November 26, 2009 - 01:43:42 AM »
Thanks,
With the block being a siamese bore, does it make it less streetable/have a possibility of overheating?
