Magnum Water Pump on LA block
Author Topic: Magnum Water Pump on LA block  (Read 1422 times)
Offline the_engineers
« on: November 24, 2009 - 08:08:16 PM »
Can the Magnum timing chain cover and water pump be used on an LA block?  I want to use the serpentine belt set-up and there are plenty of Magnum 3.9's, 5.2's and 5.9's in the yards around here.
Brooks
1971 'Cuda 360
2004 Infiniti G35 6-spd Coupe
Re: Magnum Water Pump on LA block
« Reply #1 on: November 24, 2009 - 09:03:12 PM »
As far as I know it all bolts on but you will need the reverse rotation water pump as the serp system reverses the rotation of the water pump
« Reply #2 on: November 24, 2009 - 10:39:48 PM »
Thanks  :2thumbs:
Brooks
1971 'Cuda 360
Offline thedodgeboys
  • ''Normal’s Overrated''
    • THE DODGE BOYS
« Reply #3 on: November 25, 2009 - 04:16:40 AM »
make sure you get the fan it also turns backwards  :thumbsup:
Go Fast & Have Fun...
« Reply #4 on: November 25, 2009 - 09:27:31 AM »
Electric.  Boogie Woogie Woogie Boo.  :bananasmi
Brooks
1971 'Cuda 360
