They still make a rope seal kit for the rear main seal. Like what was used in the old days. Also check your crank case ventilation system and be sure it is clean , installed right, and working propperly. This is a must. If your rings are worn, or you have blow by, this can cause the seal to leak to. Also if you are running 1 extra qt to much in the system, it will cause the leak.
Look at the back of the block to. Up by the bell housing top. Be sure the leak isnt the oil sending unit or mechanical oil line. And also the back of the valve cover gasket running down the back of the block. Or even the rear oil pan bolts to tight/loose/ You also have a cam plug and oil galley plugs behing the bell housing
