Author Topic: Headliner install time, any advice??  (Read 2956 times)
Offline lime73
« on: November 26, 2009 - 11:43:56 AM »
Does anyone have advive as to where to purchase a new headliner for my 73 Cuda?  And does anyone have any install tips?  Never done anything like this so a learning curve from the start.
wagesofsin
Re: Headliner install time, any advice??
« Reply #1 on: November 26, 2009 - 01:00:55 PM »
talk to mopardave at roseville.
hes a site sponsor.
thats where i got mine, super deal, super price.
heres a link to install.
http://restorick.com/tech/topic.asp?TOPIC_ID=5
Offline Grasshopper
« Reply #2 on: November 26, 2009 - 01:11:37 PM »
Awesome timing!!!  I'm going to start the same project this weekend.  Never done it either.  Thanks for the thread!!
« Reply #3 on: November 26, 2009 - 07:24:09 PM »
If yer old n over weight, it will make you hurt in all those positions.  Taking the front seats out really help. The directions are in the box.
Offline lime73
« Reply #4 on: November 26, 2009 - 08:10:04 PM »
i figure now is the time as there is no interior in the car at all
Offline 500Stroker
« Reply #5 on: November 26, 2009 - 09:10:03 PM »
It would be even easier if the front and rear glass was out.  I did mine last year and said never again.  A clothes steamer works great for getting the wrinkles out.
« Last Edit: November 26, 2009 - 09:13:40 PM by 500Stroker »
Offline miketyler
    • www.miketyler.net
« Reply #6 on: November 27, 2009 - 07:32:14 AM »
Also you REALLY need a heat gun. If you dont have one it will take you all day with a blow dryer.  Pick up one of the orange ones at Harbor Freight for 9.99
72' Cuda restomod
70 Mustang Mach 1
01' Honda 1100 Shadow Sabre
96' Seadoo Challenger
Offline mopardave
  • Sponsor
    • rosevillemoparts
« Reply #7 on: November 27, 2009 - 10:31:33 AM »
as for the headliner it is in stock 65.00, cover sail boards to match 22.00. Installation should be done with the windows out for ease of stretching, if the windows are in not so good to stretch front to back, Will need a steamer to aid in soffening and stretching, need trim adhesive and the side pinch weld clips if you do not have.
Mopar Dave
Rosevillemoparts.com
70 FK5 Challenger RT/SE
70 FC7 70 Road Runner - Sold
71 FM3 Challenger RT
73 F8 Challenger
1990 XJ - sold
2000 Dakota Quad Cab
Offline miketyler
    • www.miketyler.net
« Reply #8 on: November 27, 2009 - 07:01:44 PM »
I did mine with heat gun and glue - came out beautiful! Did take some time stretching working from front to rear. I used RestoRicks guide. Worked great.
72' Cuda restomod
70 Mustang Mach 1
Offline cjm
  • 70 Cuda - In Progress.....
« Reply #9 on: December 02, 2009 - 01:21:01 PM »
One other tip ---  When you remove the the shoulder belts, mirror, etc... , put the screws back in "before" installing the headliner.. Then "after" you put the headliner in, "feel" for each screw...  then with a razor, make a small slice on top of the screw and then remove it...  then put the mirror, belt holders, etc.. on one at a time.......  it makes it alot easier then searching for each screw "hole", after putting the headliner in........
