Home
Member Rides
Forum
Sponsor Sites
Tools
Contact
News:
Home
Help
Search
Chat
Login
Register
Cuda-Challenger.com
Chryco's Tech Shop
Electrical
(Moderator:
Chryco Psycho
70 Cuda Road Lamp Issues
« previous
next »
Print
Pages: [
1
Author
Topic: 70 Cuda Road Lamp Issues (Read 1659 times)
Slotts
Sr. Member
on:
November 28, 2009 - 08:00:42 PM »
I was asked to take a look at these two unworking setups. Both switches and relays were DOA and the harnesses had some issues. Thought you might get a kick out of seeing the insided of a road lamp relay. Both internal leads were broken off. Once opening and manually pressing the relay closed showed -5 and the other -7 ohms on the output side. Doesn't sound like much, but a dash dimmer switch swings between 0 and -12 ohms before cut off, meaning if this setup worked, they would have been about have as bright as they should have been. I would have liked to have glass beaded and zinc plated these relays, but they weren't mine. These toys are ok now.
One thing I found strange knowing these relays came out of a Cuda and AAR were the part numbers on both being 2889916 and not starting with a 29#####. Those relays must have been used on a B body previously.
I can't believe the "engineering" back then on some of these parts.
Slotts
Logged
GoodysGotaCuda
Sr. Resident
Re: 70 Cuda Road Lamp Issues
Reply #1 on:
November 29, 2009 - 12:32:56 AM »
looks like fun! where do you find the factory connectors for these (spades, and such)?
Logged
Build Page:
Goody's 'Cuda Build Page
1976 Dodge Warlock
Wheel & Tire Specs:
Link
Bullitt-
Permanent Resident
Better Things To Come Member Since 2/16/06
Reply #2 on:
November 29, 2009 - 10:13:41 AM »
Yea the ole electromechanical relay...One of my first summer jobs at GTE was working around & on a machine that wound those, a Bachi coil winder, about the size of a cement mixer. They were the part that made the bells ring in your phone. You will still find a version on your clothes & dishwasher water valves, although they are encased in plastic.
Looks a lot like this horn relay
http://www.napaonline.com/Search/Detail.aspx?A=ECHHR144_0222223279&An=599001+101975+50020+2020028#
Last Edit: November 29, 2009 - 10:18:02 AM by Bullitt-
Logged
Wade 73 Rallye 340..'77 Millennium Falcon...13 R/T Classic
Huntsville, AL
Slotts
Sr. Member
Reply #3 on:
November 29, 2009 - 05:39:57 PM »
Quote from: GoodysGotaCuda on November 29, 2009 - 12:32:56 AM
where do you find the factory connectors for these?
I get them from Bill Evans. I am going to make a run up to see him soon and could pick some up for you. Let me how many and what types you would need. Send me a PM if you could with what you are looking for.
Slotts
Logged
Print
Pages: [
1
« previous
next »
Cuda-Challenger.com
Chryco's Tech Shop
Electrical
(Moderator:
Chryco Psycho
