If there is a registry for your make & model you can send a tag photo / broadcast sheet scan in. This way there is a record of what you had at another location as a backup if anything happens to your originals.
Keep in mind also, if you send a low resolution scan, a blurry photo or a black & white photo copy, that is what you will get back if you need it. So, take the time to get clear high resolution images.
