Author Topic: Rotisserie headroom  (Read 2437 times)
Offline Mike70
  • Future Challenger Pilot
Rotisserie headroom
« on: December 01, 2009 - 10:18:34 AM »
What is the absolute minimum ceiling height for using a rotisserie? I'm thinking about a homebuilt using 2 engine stands. I don't think I will have to completely turn it over, but getting it at a 45 degree angle would be nice. I'm too old to lay in the floor for weeks getting all the underside done.
If only I had built my garage with 10 foot ceilings. :violin:
Thanks, Mike
70 Challenger RT/SE
(If I ever get it done - wait, I guess I have to start first).
Re: Rotisserie headroom
« Reply #1 on: December 01, 2009 - 11:04:27 AM »
I'm 5'11" if that helps estimate it's height.
Offline Mike70
« Reply #2 on: December 01, 2009 - 04:15:16 PM »
Looks like it might just squeak by. Maybe. Thanks for the photo.
70 Challenger RT/SE
Offline torredcuda
  • Epping NH joined 11/23/03
« Reply #3 on: December 01, 2009 - 05:42:25 PM »
My garage ceiling is only around 8' or so and I modified a homemade rotisserie so that it will just clear the floor and the ceiling with my 70 road runner on it.
Jeff
72 Barracuda 340/4spd  Torred
04 Ram 2500 5.7 Hemi
Offline Deece
« Reply #4 on: December 01, 2009 - 10:29:27 PM »
The ceiling on the side of the garage where I have my 74 Barracuda on a rotisserie is 8ft.  And my rotisserie is built from US Car Tool's 1st run of rotisserie 'kits' (get all the hardware & laser cut parts but source the steel tube locally & weld it all up). It barely won't clear the shop florescent lights with the wheels on the rotisserie.... I knew I'd regret spending the extra money for the bigger 8 inch metal caster wheels that would roll easier  :rofl: I've got a 6 inch set, but need to make the mounting stubs with caster bolting plate to swap out and it should spin 360 degrees without a problem.
Offline fantum
« Reply #5 on: December 01, 2009 - 10:46:15 PM »
If you don't mind my asking, how much was the kit and what did it include?
Offline the_engineers
« Reply #6 on: December 01, 2009 - 11:29:44 PM »
How wide is a 'Cuda?  Add a foot to that.
Brooks
1971 'Cuda 360
2004 Infiniti G35 6-spd Coupe
Offline Mike70
« Reply #7 on: December 02, 2009 - 10:52:18 AM »
 :useless:
Please post up some photos. i can't afford a "real" rotisserie, so I'm looking at something home built. Like to know more about the US Cartools kit too.
Thanks!
70 Challenger RT/SE
« Reply #8 on: December 02, 2009 - 11:18:15 AM »
Thanks!
The engine stands vertical bar height probably won't be high enough. The base width (wheel to wheel) doesn't seem very wide either IMO. I bought mine for a $1,000 delivered. It can hold up to 3,500 lbs. on it. It's powder coated also.
« Reply #9 on: December 02, 2009 - 11:23:03 AM »
Take a look at this if you're still inclined on DIY.
http://members.tripod.com/mopar_roadster/body_rotisserie.html
Offline 426HEMI
« Reply #10 on: December 02, 2009 - 11:48:49 AM »
Where did you get one for $1000.00 delivered?
1970 M46 Barracuda
1998 Dodge Darango
Gordon
« Reply #11 on: December 02, 2009 - 11:58:18 AM »
I was at the SEMA show in Las Vegas in 2007. They had a special deal then on them if you bought one there. The name of the company was Quality Tool & Equipment out of So. Cal.
http://www.bestbuyautoequipment.com/Auto-Rotisseries-s/420.htm
Contact Joe Marsh 951-514-5539
carshowjoe454 at yahoo . com
I think they're the best deal out there for the $
Offline Mike70
« Reply #12 on: December 02, 2009 - 03:26:23 PM »
That looks really sweet, but I just don't have $1K to put in it. I'll check out the other link. I may be laying on my back after all.
Thanks for the info.
70 Challenger RT/SE
« Reply #13 on: December 02, 2009 - 05:24:36 PM »
Before you dedicate on DIY, price out everything. The big square tubing per ft. will run quite a bit if you plan on a stronger unit.
When I bought mine, steel was astronomical per lb. So I knew it was the better choice buying one already made. Plus the fact that when I'm done with it, I know I can sell it and get most, if not all my money back for it.
Offline Deece
« Reply #14 on: December 02, 2009 - 10:19:56 PM »
This is the only pic I still have of it in my photobucket account
I bought my US Car Tool kit a few years ago, I think it was closer to $250 then, looks like its $375 now.  The kit is basically all the laser cut pieces... gussets, position lock ring, and castor wheel plates and then the spindle/hub assembly. Can get the hydraulic rams from your local Harbor Freight or equivalent.
