I have decided to go with adding add-a-leafs to bring my rear end up a little.....and I need to order new u bolts.
I measured the overall length to be 7", the inside length to be 6 1/2" (it being a 1/2" sized u bolt)....and the distance between the two centers of the "arms" of the ubolt is 3 5/8". That would seem to indicate I have a 3" axle tube.
I have an 8 3/4" rear end.
Can someone confirm that this sounds right?
I guess the key sizing questions I have is: What size hole is in the plates for the u bolts and what size tube is the axle tube?
I figure I will need to add a half inch for the add a leafs on the inside length, right?
When they list the length/size of a ubolt as "7", is that overall size or "inside" size?
Thanks guys!
