Need fitting for Auto Meter gauge?????
Author Topic: Need fitting for Auto Meter gauge?????  (Read 2343 times)
Offline GoodysGotaCuda
Re: Need fitting for Auto Meter gauge?????
« Reply #15 on: December 06, 2009 - 07:47:19 PM »
Goody it is 1/4...
Tom
The hole on the right side is 3/8 though.
http://www.sportcompactonly.com/manuals/Brand/Edelbrock/7576.pdf
There is one 1/4" and two 3/8" holes on that manifold. In the coolant circuit at least. My manifold is below, it's a performer rpm which has the same ports as the air gap. The left is 1/4" (autometer electric water temp gauge), the brass temp sender next to it is 3/8" (painless e-fan temp sender), the t-stat is in the middle, to the right of the t-stat is another 3/8" plug.
« Last Edit: December 06, 2009 - 07:55:42 PM by GoodysGotaCuda »
1976 Dodge Warlock
Wheel & Tire Specs:Link
Offline Glennster
« Reply #16 on: December 06, 2009 - 08:12:41 PM »
We just got back, I forgot the camera. I would have liked to show pictures of this. It '' WAS '' a 1/4'' or maybe a 5/16'' hole. But it was not 3/8, I know some of you think this is not possible....but I have no reason to BS anyone.
 I just drilled it with a 9/16'' drill bit and tapped it with a 3/8'' NPT tap.
NOW, it is 3/8'' and the fitting is in place.
Thanks for the help!!!
Offline 422STROKER
  • Member Since 6/3/06
« Reply #17 on: December 06, 2009 - 08:17:51 PM »
Goody did you look at my link?
Kit Contents
1 – 1/8-27 Pipe Plug
1 – ¼-18 Pipe Plug
1 – 3/8-18 Pipe Plug
Tom :wave:
Glennster glad you got it sorted. :cheers:
Tom
« Reply #18 on: December 06, 2009 - 10:17:38 PM »
 :clapping: Glad you got it all sorted out! :2thumbs:
