Author Topic: Just some more bodywork questions...  (Read 1702 times)
Offline DodgeFreak
  • Cars and trucks are my friends..
« on: September 01, 2004 - 09:14:57 PM »
Ok...i've started removing rust and what not from the floorpan...do i have to remove all the paint to the baremetal or just where rust is present and paint flaking?? also i'm useing a wire wheel on a grinder is that ok?? and then i fund a couple of holes in the floor about the size of a pencil...do i just use the welder and tack the holes shut and then grind smooth?? and last but not least...can i use a wire wheel on the outside of the car to remove rust\body filler and what not?? thanks..
74 Plymouth Duster- restoring
77 Dodge D150 shortbox- as long as i don't change my mind will be a step side dually diesel or a 383 powered truck
04 durango 4.7
Offline 360 'CUDA
Re: Just some more bodywork questions...
« Reply #1 on: September 01, 2004 - 09:56:09 PM »
Oven cleaner works OK on floor panels. Don't sniff it ;)
A mild solution of pool acid and water can do nice work on that rust as long as you keep it mild
Some paint can be left on if you want
Don't go crazy with the wire brush wheel, wear goggles and a face shield
The rust spots will win against just a welder, you need to make patches even if they are just little
patches. Rust burns, it does not weld.
Wire wheels have they're place, in corners and on rust.
It would take forever to do the whole body and make a mess
A 15 dollar can of paint remover at Home Depot will go along way towards stripping off that old paint
Offline DodgeFreak
« Reply #2 on: September 02, 2004 - 04:56:34 AM »
thanks...  ;D
04 durango 4.7
Offline HemiDog
  • Do not Assume!
    • Hemi Dog
« Reply #3 on: September 02, 2004 - 01:33:42 PM »
Another word about pin holes and pits in the metal:  It is tempting to weld them shut and grind them down, but when the metal is thinner than the stock gauge that you have your welder set for, it will burn through, usually pretty easily, and create larger holes!  I do that all the time. ::)
Offline Steve
  • I Love Welding!
« Reply #4 on: September 04, 2004 - 01:06:56 PM »
Mechanical stripping is under rated in my book. I've had some great luck with the stripping wheels. Wire wheels don't work nearly as well in my experience. I have a pic of two of my favorites. Each stripping pad is similar in construction. The one in the package is made for a 4.5" grinder and the other is made for a die grinder. The lower pic shows a tail panel that I stripped with the small die grinder wheel. Just make sure to use a face shield, goggles, and a mask/respirator. It's a dirty job, but I found that it's actually easier than sandblasting. The bad part is that the nooks and crannies are hard to get to.
As for the floor pans, POR does make a repair kit where fiberglass cloth is actually used to fill in the pinholes and such. I personally replaced 3 of the 4 pans in my car. One of the pans is solid enough for me to make small patch pieces to weld in. Welding to fill in pitted areas can be tough. I have done it, though, especially on my tail panel. I start with probing with a sharp tool to find the absolute weak spots and I actually try to poke through as much metal as possible. If the resulting hole is very small, I'll just fill with mig weld. If a pitted area stands up to the probing, I'll fill the pitted area with a mig weld. My strategy is to actually burn out the pits then back fill starting from the edges of the good metal and work inward. I then grind the metal flush on both sides.
If the pitted area is larger than a dime or so, just cut/grind it out and fab up a small patch piece. Remeber to use 20 gauge sheet metal and not the 22 gauge stuff.
[attachment deleted by admin]
Offline DodgeFreak
« Reply #5 on: September 06, 2004 - 08:53:14 PM »
I'll try to get pics of the floor pan and tell me what you think i should do...also..........that thing on the die grinder looks like something i thought about getting at wal-mart... in the automotive paint section... ;D
04 durango 4.7
Offline Steve
  • I Love Welding!
« Reply #6 on: September 07, 2004 - 09:35:43 AM »
Yep...I bought the small one at Harbor Freight and I picked up the purple one at Autozone. Make sure to wear a dust mask or respirator when using these things!
Offline DodgeFreak
« Reply #7 on: September 07, 2004 - 04:15:30 PM »
Yup...I've got a mask and a full faceshield and stuff....been using em.... ;D
04 durango 4.7
