I forgot to mention that while in there I was dinking with the turn signal cam and....whoops! snapped off the right turn tang!
But on the plus side, I was able to install, and get it to work, a complete lock cylinder with key housing thing and key in buzzer tang, I had from the 74, by drilling a hole in the 70 housing because, you guessed it, different than the 70 cylinder (I was just gonna use the 74 housing, but it's green and needs to be refinished)
After thorough examinations of the column, I think it is out of something other than a E-body (no depress lever to remove key" thing and that they just swapped what they could from the 70.
