Author Topic: help with interior prep  (Read 579 times)
Offline vpittman
« on: December 06, 2009 - 05:52:56 PM »
I'm looking to start working on the interior of my '73 cuda... The floorboard and trunk have light surface rust...
I plan to cover it with B-Quiet soundproofing or something similar...
Should I just lightly clean it and coat it with por-15 or get a soda blaster (about $100 at harbor freight), blast it and use primer ?
I should add that this is going to be a driver, a nice one, but not a show car...
Thanks !
« Last Edit: December 06, 2009 - 06:02:19 PM by vpittman »
Offline 72rtchallenger
  • 72 to 70 clone
    • cardomain
Re: help with interior prep
« Reply #1 on: December 06, 2009 - 06:16:29 PM »
i used the por 15 after i sand blasted,,just ruffed up the surface before coating  :2cents:
72rtchallenger
what happens in the garage
stays in the garage
« Reply #2 on: December 06, 2009 - 06:24:25 PM »
Light rust I'd hit with a wire brush on an angle grinder if you have one, if not a drill
wagesofsin
« Reply #3 on: December 06, 2009 - 07:28:59 PM »
just clean up the surface,i.e. remove all scale, corrosion etc as was mentioned in the other posts.
make sure all large particles are gone, clean with some good degreaser.
allow to dry, and treat.
you should be fine.
 :2thumbs:
