Author Topic: 340 advice  (Read 838 times)
Offline lazerboat
  • whatz done is done
340 advice
« on: December 07, 2009 - 10:49:27 PM »
I have a 72 340 it was rebuilt before i purchesed it so i pulled the heads and checked cylinders 4.64  60 over  i think
they seem out of round about .04 thousand of inch,  is that norm ?    The  pistons have 4 valve releafs in them are they stock ?    And sit in the hole about .110 thous. Can I just change out the pistons for higher compression ones and if i do will i have to balence the assy.       Im looking for a good cheap build  i have a set of 302 heads stock  and also  ported j heads what would be better  ,  is a block  that is 60 over  any good   thanks for any help   :swear:
Re: 340 advice
« Reply #1 on: December 07, 2009 - 11:10:52 PM »
Stock bore is 4.04 so .060 over would measure 4.1"
if the bores are out of round by .040 the block is junk , if they are out by .004 you will still not get the bores round without boring out to .070 over & yo u would need a custom piston if the block checks out at that bore for adequate wall thickness
 the 302 heads are a small port head designed for the 318 but I know a ported 308 head will out flow the X&J heads so I am not sure if the 302 would as well
Offline 72rtchallenger
  • 72 to 70 clone
    • cardomain
Re: 340 advice
« Reply #2 on: December 07, 2009 - 11:20:37 PM »
72rtchallenger
what happens in the garage
stays in the garage
Offline lazerboat
Re: 340 advice
« Reply #3 on: December 08, 2009 - 06:21:28 PM »
sorry i think  i ment the cylinders are 4.064  is 20 over  is that correct  it seams they are out  of round buy about .004 across the board , the engine seems pretty fresh i can still see the honing marks fantly. are the pistons norm to be .110 in the hole for 72  and do  you think i  could  change to kb pistons  re hone and ring thanks for you help  :burnout:
Re: 340 advice
« Reply #4 on: December 09, 2009 - 03:31:46 AM »
you need to make the cylinders round to get them to seal
so I would fit the pistons to .030 oversize
Offline moparnut
    • My Photo's
Re: 340 advice
« Reply #5 on: December 15, 2009 - 06:57:57 PM »
you mean they dont sell out of round pistons? :clueless:
could have sworn cheby does :bigsmile:
2012 Subaru Forester
70 D100 Adventurer 383 pickup
06 Honda VTX1800S Spec 3
