Author Topic: What CFM 4-Barrel would match up with stock 68' 318?  (Read 5733 times)
Offline wally426ci
    • maryland mopars
« on: December 09, 2009 - 08:12:44 AM »
Looking to swap over to a Carter or Edelbrock on my 318. I have a 68 4-Barrel Cast Iron intake.  :burnout:
 :bigsmile:
{OOI====I====IOO}
      '71 Challenger
      [O[]=====[]O]
      '68 D100
Offline 72cudamaan
Re: What CFM 4-Barrel would match up with stock 68' 318?
« Reply #1 on: December 09, 2009 - 08:17:45 AM »
Best bet is a 600, if you can jet carbs then go with a 650. :2cents:
If I cant fix it, it's broke
Andy  (phukker whither)
« Reply #2 on: December 09, 2009 - 09:34:01 AM »
      You know that the intake runners won't line up with your 318-heads
   Don't know what your ultimate plans are but I was reading this last night.
       They use 360 "smog" heads which would solve that problem
  http://www.moparmusclemagazine.com/sch/04/318-Small-Block-Budget-Build/--2d--/articles/index.html
« Reply #3 on: December 09, 2009 - 01:16:28 PM »
The best combo I have found is the later police 318 44bl intake from the diplomat & the Holley 570  Avenger series as it is about the smallest carb I can find
Offline wally426ci
    • maryland mopars
« Reply #4 on: December 09, 2009 - 01:21:02 PM »
Hmm.. I didn't know about the intake compatibility. I'll keep an eye out.
I didn't really get a whole lot from that article, i didnt see any referance to intakes...  :clueless:
{OOI====I====IOO}
      '71 Challenger
      [O[]=====[]O]
      '68 D100
Offline dodge freak 2
« Reply #5 on: December 09, 2009 - 04:21:01 PM »
On Ebay you might find a old Edelbrock with small 318 ports. The new performer intake has small ports too.
I like the Holley street dominator from the 1970's early 80's its a single plane but built for mild street use and has small ports. A dual plane will give the motor a bit better idle thou but power wise the Holley intake was darn good.
« Reply #6 on: December 09, 2009 - 04:43:23 PM »
the edelbrock LD4B was designed for the small port 318 heads & works well
Offline wally426ci
    • maryland mopars
« Reply #7 on: December 09, 2009 - 05:41:33 PM »
So are you guys saying the 340 intake absolutey won't work?? What are the differences?  :clueless:
{OOI====I====IOO}
      '71 Challenger
      [O[]=====[]O]
      '68 D100
« Reply #8 on: December 09, 2009 - 06:50:28 PM »
You can have your heads port matched, I don't know how much work that will take but if you don't you could actually hurt the performance due to turbulence in the runner.
« Reply #9 on: December 09, 2009 - 07:23:59 PM »
The 340 ports are larger than the 318 ports..so think about it, you have a big hole matching up with a smaller hole, what happens at high flow-high rpms, air flows fast but hits the ridge of the smaller 318 ports.
Yes best thing is to pull the heads off and open up the outside of the ports but a small port intake works good too, maybe better if the motor isn't built for 6,000+ rpms.
Offline vinb
« Reply #10 on: December 09, 2009 - 09:56:40 PM »
And a 625 Carter AVS....
« Reply #12 on: December 13, 2009 - 08:02:41 PM »
you cannot remove enough metal from the 318 castings to match the 340 port window
 yes you can use a 340 intake & yes it will work ok
Offline wally426ci
    • maryland mopars
« Reply #13 on: December 14, 2009 - 05:53:06 PM »
Thanks Bullit - don't know what state that is in....
Chryco, I plan on it if I dont locate something that is 318 specific. Im not exactly racing this 68 Truck with its NP435.  :lol2:
{OOI====I====IOO}
      '71 Challenger
      [O[]=====[]O]
      '68 D100
« Reply #14 on: December 14, 2009 - 07:54:17 PM »
  Googled the phone# & get the heart of PA.. Jersey Shore, PA 17740
