Home
Member Rides
Forum
Sponsor Sites
Tools
Contact
News:
Home
Help
Search
Chat
Login
Register
Cuda-Challenger.com
Chryco's Tech Shop
Suspension, Wheels/Tires, and Brakes
(Moderator:
Chryco Psycho
How to make a basic adjustment of front suspension.??
« previous
next »
Print
Pages: [
1
Author
Topic: How to make a basic adjustment of front suspension.?? (Read 1543 times)
cowboy
Sr. Member
Denmark
on:
December 09, 2009 - 05:48:01 PM »
Got all my front suspension apart, - how do I set it up for driving a little, - untill I hit an autostore that can make a prober alignmet..
Logged
MoPar's for Cruizin, Racing & Pro-touring:
www.CowboyCars.dk
1930 Plymouth Hot Rod wannabe - 1957 DeSoto Fireflite Sportsman - 1967 RaceCuda - 1968 Barracuda - 1971 Challenger R/T Conv.
Bullitt-
Permanent Resident
Better Things To Come Member Since 2/16/06
Re: How to make a basic adjustment of front suspension.??
Reply #1 on:
December 09, 2009 - 07:11:11 PM »
http://www.hotrod.com/techarticles/chassis/hrdp_0411_wheel_alignment_guide/index.html
DIY camber gauge
http://www.stangnet.com/mustang-forums/534269-diy-alignment-how-make-camber-caster-gauge.html
You can calculate your caster by measuring the distance between two vertical parallel points on the steering knuckle ,(I used the upper & lower ball joint grease fittings) Then measure these points against a perpendicular straight edge. The difference of that measurement & a little geometry & you get the angle.
http://www.csgnetwork.com/righttricalc.html
I started with the rear upper control arm bushings maximum in & the front maximum out, both sides measured the same with 2.08 degrees positive caster.
more
http://www.familycar.com/alignment.htm#Cas
Last Edit: December 10, 2009 - 07:55:52 AM by Bullitt-
Logged
Wade 73 Rallye 340..'77 Millennium Falcon...13 R/T Classic
Huntsville, AL
cowboy
Sr. Member
Denmark
Reply #2 on:
December 10, 2009 - 03:28:27 AM »
Thanx, - after all that reading I proberbly will be able to drive it to a professional..
Logged
www.CowboyCars.dk
Bullitt-
Permanent Resident
Reply #3 on:
December 10, 2009 - 08:02:51 AM »
Now you know .... I spent about 4-hours on mine, not including all the reading.
If your gonna pay anyway save all that time & just go to the pro.
Logged
Huntsville, AL
426HEMI
Sr. Resident
My M46 Barracuda! Member Since:October 01, 2005
Reply #4 on:
December 10, 2009 - 08:07:05 AM »
Just use your eyes and get it close and then take it to a pro to align it. A level might be handy too.
Logged
Got a pretty good start on my M46 optioned Barracuda restoration but now it is on hold till I can gather more funds. Still need a few parts for it. SIU Graduate 75 AAS Automotive Tech, 94 BS Advanced Tech Studies, 1997 MSED Workforce Education and Development
1970 M46 Barracuda
1998 Dodge Darango
Gordon
73Chally
Resident
Reply #5 on:
December 10, 2009 - 08:47:44 AM »
How far to the shop that will align it? If it's more than say 10 miles, I would probably look to have it towed. If you're even a little bit off on your guesstimations, you could drive it straight into a ditch if your roads are kind of rough.
Logged
Print
Pages: [
1
« previous
next »
Cuda-Challenger.com
Chryco's Tech Shop
(Moderator:
Chryco Psycho
