I found a lot of different setups with the search function.
Someone gives me the following setup configuration:
Camber: 0,5° + / - 0.25° (negativ)
Caster: 3°-5° max.
Toe: 1,5 mm -2.00 mm (0.059" - 0.787")
Is this setup o.k. and works with QA1 shoks ?
Thanks fo a little feedback
How is the car setup? Is it setup for handlings, long cruises, etc??
General Crusing
Camber -0.2 to -0.4 degrees negative. 0.2 to less on one side to account for road camber
Caster +3 to +5 degrees positive. Set highest you can get until 5
Toe 1/16 toe in
Aggressive Handling
Camber -0.5 to -1.0 degrees. The higher the more agressive
Caster +4 to +5 degree highest you can get until 5
Toe 1/16 toe in or 1/32 toe in with all brand new suspension pieces
Can run the same spec on A/B/E or whatever.
