Author Topic: 383 Help  (Read 1408 times)
Offline Bart
383 Help
« on: December 11, 2009 - 11:19:34 AM »
Well since I sold my 34 3 window, I have started on working on my Cuda, I pulled the numbers matching motor, wrapped it up and got a 71 HP 383 to build. I have the block at Kim Barrs racing and he's getting the block ready.  I got some Diamond Pistons made for it and now looking at cams.
Can anyone give me a good idea on what cam for the street would be good, going with Edelbrock heads.
Regards,
Steve
« Last Edit: December 11, 2009 - 11:21:55 AM by Bart »
1970 Cuda 383
2008 Titan
2010 G37s
1996 Advantage Victory 27 502ci
2013 HD Roadking
Re: 383 Help
« Reply #1 on: December 11, 2009 - 12:31:02 PM »
need more info , intake , rear gear , basics like solid or hyd or roller cam grind
 I have been using Lunati primarily for cams now since Engle was sold to new owners , I custom grind the solid cams & use the VooDoo hyd grinds
Offline Bart
Re: 383 Help
« Reply #2 on: December 11, 2009 - 01:44:32 PM »
Thanks Cp,
looking for a hyd cam, intake is Edelbrock PRM dual plane, rear end gears, approx 3:73 somewhere around there. so with that can you make a suggestion.
Regards.
1970 Cuda 383
2008 Titan
2010 G37s
2013 HD Roadking
Re: 383 Help
« Reply #3 on: December 12, 2009 - 11:28:17 AM »
I do not have my catalog in front of me but I thnk the # is 60303 or 60304
