Home
Member Rides
Forum
Sponsor Sites
Tools
Contact
News:
Home
Help
Search
Chat
Login
Register
Cuda-Challenger.com
Chryco's Tech Shop
Engine & Go Fast Goodies
(Moderator:
Chryco Psycho
help oil leaking
« previous
next »
Print
Pages: [
1
Author
Topic: help oil leaking (Read 514 times)
tvacuda340
Jr. Member
F1A procharger 422 small block
help oil leaking
on:
December 11, 2009 - 02:09:51 PM »
hi
big problems
oil is leaking behind ol filter plate
i use 1 gasket .. the 2 gasket
look like i need 3 thik gasket to get it seal probber
i am doing something wrong ..??
Logged
72cudamaan
Resident
Re: help oil leaking
Reply #1 on:
December 11, 2009 - 04:02:10 PM »
The plate might be slightly bent. Are you sure that its not a leaky oil seal on the filter?
Logged
If I cant fix it, it's broke
Andy (phukker whither)
tvacuda340
Jr. Member
Reply #2 on:
December 11, 2009 - 04:43:55 PM »
I think .. i using the wrong filter plat it have6 holes the old on had 4 !!??
are they difference plat ? for differenc years
it is a 340 la
Logged
ShelbyDogg
Sr. Resident
Reply #3 on:
December 13, 2009 - 09:04:06 PM »
Should only use 1 gasket around outside and one small gasket under middle. Make sure that block surface is clean all the way around and use brake cleaner then gasket sealer on both sides of gasket to make it stick. Make sure plate isn't bent AND clean. 6 holes or 4 holes doesn't matter.
Logged
moper
Resident
Reply #4 on:
December 14, 2009 - 05:40:34 PM »
Emphasis on CLEAN... no silicone, no fingerprints... I routinely drill extra holes in that plate so it's not a big deal. But you want to make sure the parts are not warped and you have the right gaskets.
Logged
Print
Pages: [
1
« previous
next »
Cuda-Challenger.com
Chryco's Tech Shop
(Moderator:
Chryco Psycho
help oil leaking
