Author Topic: fuel line questions  (Read 650 times)
Offline 70 RAG TOP
fuel line questions
« on: December 15, 2009 - 05:04:59 PM »
Hey all,
My question(s):
Iam getting ready to install my rebuilt 383 mag(+.30 over) in my 70 chall.  While I am at it, I would like to update some parts.
The car has been sitting unused for long periods of time and the tank has bad gas in it.  I cleaned and sealed the inside of the tank w/ gas tank sealer about 10 years ago.  The fuel lines on the car (from front to back) are original.
Q #1:  In your opinion, should I just spend the $60 for new fuel line from front to back?
Q#2 : Is there a product or chemical that will disolve varnish deposits in the tank without harming the seal coating?
Q#3 : Will the 5/16" line provide adequate fuel delivery for my rebuilt 383? (The sending unit is probably 5/16" and the fuel
         pump is 5/16")  would 3/8" be overkill?
Thanks in advance,
Re: fuel line questions
« Reply #1 on: December 15, 2009 - 05:12:44 PM »
I would replace the lines & use the 3/8 line
« Reply #2 on: December 15, 2009 - 05:21:21 PM »
You can get by with the 5/16" lines, but if the fuel pump is old, I think I would swap that out too. The rubber diaphragm could be showing age.
