Author Topic: driveshaft interchangeability  (Read 1015 times)
Offline challenged72
« on: December 15, 2009 - 11:27:09 PM »
So Im going to be asking a lot of stupid question over the next few weeks, Im a newbie to Mopar and Im re-assembling my challenger.
Im buying a smallblock 360 and trans, both crate man. in 94, both ready to drop in, at a great price. Has alternator, EVERYTHING but carb.
What I need to know is will my BB driveshaft mate to the 727, and will this 727 even fit?
I know I'll need small block engine adaptors, any suggestions on where to get them? Anything else other than radiator and mounts?
Thanks a million
Offline Mentally Challenged
Re: driveshaft interchangeability
« Reply #1 on: December 16, 2009 - 12:29:13 AM »
The 727 will fit fine, I am not sure on the driveshaft. I'm sure somebody will chime in to help with the driveshaft.
Chris, Ohio
« Reply #2 on: December 16, 2009 - 12:55:39 AM »
a big block 727 will not fit a 360 engine. But the bb 727 shaft will fit the sb 727.  But a dana shaft is shorter than an 8 3/4 and a challenger shaft is a different length compared to a cuda shaft.
What rearend is in your car?  The smaller rears take a different length too
« Reply #3 on: December 16, 2009 - 01:43:49 AM »
411 posi supposedly but Ive never checked
how can I check?
« Reply #4 on: December 16, 2009 - 02:38:32 AM »
:iagree: I assumed when he said he bought the 360/727 together it was a small block 727 not bb
how can I check?
Al needed the size of the rear, such as 8 3/4 8 1/4 or Dana 60
Chris, Ohio
« Reply #5 on: December 16, 2009 - 12:12:15 PM »
the rear end of the 727 is in the same place with either the big or small block so assuming the diff is not being changed the driveshaft will drop in
« Reply #6 on: December 20, 2009 - 06:05:46 PM »
So ignorant question, how can I tell which size rearend it is? Thanks
 :2thumbs:
Offline mopardave
  • Sponsor
    • rosevillemoparts
« Reply #7 on: December 20, 2009 - 06:33:58 PM »
if it has a differential cover then it is a dana or 7.25, if it is a solid housing with the pig or center section only removes from the front then it is an 8.75
the two word documents are drive shaft dimensions, i couldn't get the PDF page to load
« Last Edit: December 20, 2009 - 06:37:18 PM by mopardave »
Mopar Dave
Rosevillemoparts.com
70 FK5 Challenger RT/SE
70 FC7 70 Road Runner - Sold
71 FM3 Challenger RT
73 F8 Challenger
1990 XJ - sold
2000 Dakota Quad Cab
Alaskan_TA
« Reply #8 on: December 20, 2009 - 06:34:22 PM »
Some 727 tailshafts are different lenths, so if your new one is the same length as the old one, then yes, you can use the same shaft.
If you have console shift, be sure the mounting ears for the bracket are on your new one also.
