Author Topic: Been chasing a noise under the hood.........  (Read 1560 times)
Offline Oldschool
  • Member Since 9-05-06
« on: December 16, 2009 - 11:46:53 AM »
Like the title says, I have been chasing down a ticking sound. It sounds like a loose valve tapping. I have checked all of the valves twice and they are set correctly. I even removed the rocker shafts and rocker arms to check them out. Everything checks out normal.  Plenty of oil, no signs of any issues. I hear it when driving, but when the car is at idle and I am listening for it under the hood, I can't hear it. I have used a 3/4" dowel rod and pressed it to every section of the motor while running and all I can hear is a rotational whirring sound  --  no tapping. I am beginnning to think it is a header leak. I was hoping that wasn't the case because those tings are a bear to change.    :working:  I think I will replace those over the next few weekends and see what happens. Any other ideas that I haven't thought of?    :dunno:
Thanks.....   :2thumbs:
Ken  --  In Georgia
Re: Been chasing a noise under the hood.........
« Reply #1 on: December 16, 2009 - 12:16:48 PM »
Is it for sure related to the engine...speeds & slows with engine RPM?   I have had a ticking from wheels/brakes/bearings that sounded just like a lifter but was vehicle speed related.
« Reply #2 on: December 16, 2009 - 12:18:12 PM »
are you using a mechanical fuel pump , it could be the rod , if you have a roller cam you need a bronze tipped rod
Offline Oldschool
« Reply #3 on: December 16, 2009 - 12:25:21 PM »
Yep, it is engine speed related.....     :grinyes:
Ken  --  In Georgia
Offline Oldschool
« Reply #4 on: December 16, 2009 - 12:27:30 PM »
Electric fuel pump at rear of car, no mechanical pump.  And it is a small roller cam....      :thumbsup:
Ken  --  In Georgia
« Reply #5 on: December 16, 2009 - 12:29:32 PM »
that is what I recalled , I have seen 2-3 other big block make the whirring noise will no problems , cannot figure what makes the noise
Offline The Cuda Guy
  • Support Our Troops
  • Pearl Harbor, HI
    • C-C.com
« Reply #6 on: December 16, 2009 - 11:16:05 PM »
Here is my standard answer...  header gaskets????
Member Since January 14, 2002
Offline Oldschool
« Reply #8 on: December 17, 2009 - 09:53:28 AM »
Alshymer?
 :roflsmiley:
http://www.cuda-challenger.com/cc/index.php?topic=63959.15;topicseen
 :roflsmiley:    :smilielol:
Hey Al, that's not funny....    :poopoke:
I was thinking of my issue when I posted in that thread..   :grinyes:
I have been hoping my issue was a loose valve or something easy to remedy. If you have ever changed header gaskets on an Indy headed Hemi in an "A" body with custom built 2-1/4" headers, you will understand why I hate to begin that process....    :working:    Probably 8-9 hours at best of solid working...     :faint:   That is if everything goes just right....    :banghead:
Ken  --  In Georgia
« Reply #9 on: December 17, 2009 - 01:40:31 PM »
Maybe Me & Al need to roll down 278 & give you a hand..  Then it would take only 10 or 12-hours.  ;)
Offline Oldschool
« Reply #10 on: December 17, 2009 - 01:44:15 PM »
I suspect there would be a lot of discussing the best way to approach the task, talking and laughing in general, telling war stories, tipping back a cold beverage, and BS'ing in general.   :blah:   Probably wouldn't get a whole lot of work done though......     :roflsmiley:    :bigsmile:
Sounds like fun, when can y'all be here??     :clapping:    :woo:    :ylsuper:
Ken  --  In Georgia
« Reply #11 on: December 17, 2009 - 02:18:55 PM »
My weekend is wide open... See what Alan has to say.
« Reply #12 on: December 17, 2009 - 02:36:09 PM »
Im up if needed. I got a set of hemi headers to :bigsmile: But there B/E body style.  I think with the coolant drained, the car on a 4 post, and the tools rolled up right there, I could slip that gasket in and out quicker than 8 hrs.
Oh, I dont recall, does the coolant get drained on a hemi?  Either way nuts, buts, adhesive, gaskets and fun chat .......  No charge for the fellowshipping/labor Ken.   You just had a birthday. We can do all this in between your senior citizen nap times :stirpot:
Offline Oldschool
« Reply #13 on: December 17, 2009 - 02:57:13 PM »
Thanks fellas, you guys rock!   :ylsuper:
The passenger side headers are practically inaccessible unless you have hamster hands...  lol    :roflsmiley:
No coolant to drain, just thousands of attempts at getting a few of the hidden bolts started....    :pullinghair:  I have done it before, I just ain't looking forward to doing it again.....     :faint:
I'll try and get it done in the next few weekends. The next few are busy with the holidays, but soon after I will tackle the job....     :working:
Ken  --  In Georgia
« Reply #14 on: December 17, 2009 - 03:05:25 PM »
You guys let me know when...I'll get my BFH polished up
