Author Topic: Need pics of `cuda taillight blackout area.  (Read 2366 times)
Offline torredcuda
  • Epping NH joined 11/23/03
« on: September 04, 2004 - 06:06:16 PM »
OK.I still can`t decide on what stripe to order but I have decided to blackout my tail panel so I need some pics and info as to exactly where to tape off.If you guys come thru quick enough I might even have  it done Monday since it`s a holiday.  :D
Jeff
72 Barracuda 340/4spd  Torred
04 Ram 2500 5.7 Hemi
Offline Steve
  • I Love Welding!
Re: Need pics of `cuda taillight blackout area.
« Reply #1 on: September 04, 2004 - 10:29:19 PM »
Here are a couple of pics of an extra original tail section that I have. I don't have a pic of the top side of the panel, but I can tell you that the blackout goes up about half way to the trunk lip seal. I can take a picture of that tommorow (weather permiting).
[attachment deleted by admin]
Offline 360 'CUDA
« Reply #2 on: September 05, 2004 - 12:22:25 AM »
You have to improvise
Without the 'CUDA chrome on the tail I did it this way
I thought it turned out OK
Offline shaker71
« Reply #3 on: September 05, 2004 - 03:20:05 AM »
Here is a pic of what mine looks like right now. Its how i bought it. If its any help.
Offline torredcuda
« Reply #4 on: September 05, 2004 - 05:47:47 AM »
I`m not worried about correct since I don`t have the mouldings either,just wanted to get some ideas on how the factory and you guys did yours.Steve or Shaker,could you get me a pic of the top flange area where it goes into the trunk lip?I`d like a pic of that area if you wouldn`t mind.Thanks guys,I`ll post up some pics when mine`s done.
« Last Edit: September 05, 2004 - 05:49:43 AM by torredcuda »
Jeff
Offline Steve
  • I Love Welding!
« Reply #5 on: September 05, 2004 - 10:01:01 AM »
Try this and see if it helps.
Offline 360 'CUDA
« Reply #6 on: September 06, 2004 - 12:19:36 AM »
I guess I did the top like the factory did ???
I never noticed it before
Offline Steve
  • I Love Welding!
« Reply #7 on: September 06, 2004 - 10:36:54 AM »
360- your setup looks good!
Here's a question for you 72-74 guys (and gals): Do you use the chrome trim if you plan to put an AAR spoiler on the deck? AND, did the factory produce any 72-74 cars without the trim? If so, how did they do the blackout? I assume it would look like 360's.
Offline 360 'CUDA
« Reply #8 on: September 06, 2004 - 11:14:43 AM »
I don't think I have ever seen a blackout panel on a stock Barracuda
If you already have the holes in the decklid and the tail you should use the chrome but
it would probably look better without it
I bought a '74 'CUDA that had a T/A spoiler (modified to fit) with the chrome and it didn't look
too bad ;)
Offline Steve
  • I Love Welding!
« Reply #9 on: September 07, 2004 - 09:38:11 AM »
I have decklid off of a '70 'Cuda, which doesn't have the holes or studs for trim. My quarters in the rear are under construction  ;D, so I can put in the holes and studs are go without. I'll probably leave the trim off and put on an AAR spoiler. I'm definately doing the blackout treatment.
