Author Topic: Key Buzzer for 1972 Challenger  (Read 2982 times)
Offline ghjedi
« on: December 17, 2009 - 05:45:52 PM »
Hello,
My Challenger owner's manual talks about a key buzzer, but mine isn't working.  Does anyone know if the buzzer can go bad or be replaced?  Where is it located?
Thanks
1 of 1 1972 Challenger 440 4sp Convertible Blue GB2
2012 Challenger R/T Classic Blue Streak Pearlcoat
Re: Key Buzzer for 1972 Challenger
« Reply #1 on: December 17, 2009 - 06:14:41 PM »
The buzzer could be unplugged or gone bad from moisture or whatever, My car is a 70 and it is made of meteland just underneath the glove box area.  They are esy to get at and available to purchase
Offline ghjedi
« Reply #2 on: December 17, 2009 - 07:27:32 PM »
Thanks Moparal.  I'll check it out. I'm betting that mine is bad b/c everything else on the car has needed to be replaced.   :banghead:
« Reply #3 on: December 17, 2009 - 07:43:05 PM »
By '73 the Horn Relay & key in ignition buzzer are combined & found plugged into the fuse block, I believe that is what you will find on 71-74s.  Does your horn work?
« Reply #4 on: December 17, 2009 - 08:04:12 PM »
HM my horn relay is on the box and the buzzer is by the glove box.  Can a relay also be a buzzer?
« Reply #5 on: December 17, 2009 - 08:14:22 PM »
Apparently  those Geniuses at Chrysler can do anything..  :lol2:
Offline 72rtchallenger
  • 72 to 70 clone
    • cardomain
« Reply #6 on: December 17, 2009 - 08:21:47 PM »
my challenger is a 72 but sold in 71  early production,and the buzzer is in plugged into the fuse box and your problem my lie in the ignition switch wires,,mine works 50% of the time,when it quits I can move the plug at the bottom of the column that runs from the igntion and make it work again,but I put in a new buzzer before I found it
72rtchallenger
what happens in the garage
stays in the garage
« Reply #7 on: December 17, 2009 - 09:20:38 PM »
The buzzers are horrible sounding. I don't know of too many that keep it in constantly. Eventually you can't take it anymore and in the glove box it goes.
« Reply #8 on: December 17, 2009 - 09:47:37 PM »
:iagree: Sounds like a sick cat or something.
« Reply #9 on: December 17, 2009 - 11:12:46 PM »
Ya think by now somebody would offer an accessory of a woman's voice..."Your door is ajar"
« Reply #10 on: December 17, 2009 - 11:16:21 PM »
 :roflsmiley:
« Reply #11 on: December 19, 2009 - 03:56:25 PM »
