Author Topic: 1968 Fully Restored All Numbers Matching 383 4 Speed Sport Satellite. Rare Car.  (Read 1093 times)
Offline shawnmid
  • FastMetalToys.com
    • Fast Metal Toys
1968 PLYMOUTH SPORT SATELLITE! FULLY RESTORED AND JUST COMPLETED ON 8.21.2009! LESS THAN TWENTY FIVE MILES ON THE ENTIRE CAR! ALL NUMBERS MATCHING 383, FOUR SPEED, AC CAR! EXTREMELY RARE, TURN KEY, AND READY TO ENJOY! ORIGINAL BUILD SHEET, VIN, AND FENDER TAG! THE PRODUCTION NUMBERS ON THIS CAR ARE FAR LESS THEN EVEN A 1969 CHARGER RT FOUR SPEED CAR!
     What we have is a 1968 Plymouth Sport Satellite. This car is extremely rare and by our calculations, there were less than fifty of these built with the same options and probably less than five with this same color combination. If you are looking for a rare and highly sought after Mopar then look no further. This is probably the first and last time you will see one like this.
     Below you will find before and after photos as well as video of this beautiful Satellite. We also have a massive pile of receipts which will also go with this Satellite upon sale. We have had many folks stop in and look at this beautiful Satellite. Every single one comments and says that this is by far one of the best cars we have ever done.
Body: The body on this Satellite was completely stripped down to bare sheet metal, not once, but TWICE! We were so meticulous about making sure this Satellite was done right that we had them strip the car once it was painted and redo it. Yes it was costly but it was well worth it. As you will see, the drivers side quarter has been replaced with a brand new full quarter from GoodMark. The trunk pan has also been replaced. Both were done professionally and line up perfectly. The rest of the car is all original and is 100% solid. No rust, no bondo, just pure sheet metal. The frame rails, floors, fenders, roof, doors, hood, trunk extensions, jams, rockers, all original. The Satellite was repainted back to its factory correct color combination and looks absolutely gorgeous. The grill was also redone and is in excellent condition. The rear bumper is brand new and the front bumper was sent off and rechromed. All of the trim through out the car is in good shape with no major pitting or scratches and shines up perfectly. All of the glass is also in excellent shape through out the entire car. Here is just a full list of items:
New drivers side quarter panel
New trunk pan
New battery
New battery cables
New aluminum radiator
New Edelbrock carburetor
New plug wires
New Starter
New alternator
New gas tank
New sending unit
New intake (have the original to go with the car)
New radiator hoses
All new stainless steel fuel & brake lines
Fully refurbished AC/Heater core
Fully rebuilt engine
Fully restored dash
Fully restored grill
Restored woodgrain steering wheel
Console
New tail lights
New side marker lights both front and back
New weather stripping
New door handles
New side mirror
New 500 Wheels and tires (100%)
New wheel wall chrome
New rocker chrome
New trunk mat
New window crank handles
New seat covers (both front and back)
New carpet
New headliner
New arm rest and base
New hood pins (not original to this car)
New fender mounted turn signals
New antenna
New package tray
New cat whiskers
New seal plates
New dual exhaust with Flowmaster mufflers
New chrome tips
New Hemi Leaf Springs
All new front end components (ball joints, upper, lower, control arm bushings, upper, lower, inner and outer tie rods)
All new brake system (discs on the front, drum on the rear)
Refurbished 8 3/4 rear end 323 Posi
Fully restored stereo (was sent off and we do have the receipt)
New door panels
Refurbished dash
Engine & Mechanical: The 383 within this Satellite is in fact the original numbers matching motor. It has been completely tore down and redone professionally. It does have a mild cam and is in excellent working order. It does not smoke, leak, or burn an excess amount of fluids. It is in perfectly mechanical order. The four speed transmission has also been completely tore down and redone. It too is in excellent mechanical order and shifts out flawlessly as would be expected. We also installed a new clutch. The rear end within this Satellite is its original 8 3/4 with a 323 posi. It too has been gone through and is in excellent working order. This is also an original AC car and we do have everything for it and will be including it with the car. All of the electrical components through out the Satellite have been refurbished and are in excellent working order. The dash lights, gauge cluster, headlights, tail lights, dome light, turn signals, everything is in good working order as would be expected from a car of this caliber.
Interior: As you can see the interior has been completely gone through and done back to its factory correct specifications. It is all new from top to bottom, front to back.
This car is located in Kansas City, Mo. We are only asking 28,500.
http://mmbrokers.com/newcars/68SatelliteBB/68SatelliteBB.htm
Thanks,
Shawn
816.308.0351
FastMetalToys.com
