How do you clean ceramic coated headers?
Author Topic: How do you clean ceramic coated headers?  (Read 14649 times)
Offline Oldschool
  • Member Since 9-05-06
« on: December 18, 2009 - 09:28:39 AM »
Ok friends, my buddy with the 500" BB Dart has pulled the engine to do an off season freshen up under the hood. The valve cover gaskets leaked onto the headers over the entire cruising season last year. Very minor leaks, but over time, they add up.
Anyway, what is the bast way to removed those burned in oil stains from TTi ceramic coated headers?  It is apparent that the headers won't burn the stain away. What should he do???    :dunno:
Ken  --  In Georgia
Re: How do you clean ceramic coated headers?
« Reply #1 on: December 18, 2009 - 10:03:24 AM »
Here's all that TTi has to say...some applies to chrome or stainless... Fast Orange hand cleaner has worked well for me in other applications.
 After Header Installation and Before Engine Run - Remove grease and/or skin oils from the header tube surface.  Stains & fingerprints will show when header gets hot.
      Nickel Chrome Plated Headers:  Wipe down tubes with rubbing alcohol and a soft cloth, dry thoroughly.
      Ceramic Coated / Polished Ceramic Coated Headers / Stainless:  Wipe the tubes down with an environmentally safe Orange Cleaner Degreaser or mild soap, warm water and a soft cloth, dry thoroughly.
When storing your car for an extended period of time, some precautions must be taken.  Park the car over a large sheet of plastic or tarp.  This will protect your car and headers from moisture seeping up through the floor.  Wipe down and dry the headers thoroughly.  Then coat the headers with WD-40 or an equivalent where the tubes are welded to the header flanges and where the tubes come in close proximity to each other (especially where the four tubes enter into the collector).  These areas are prone to rusting, as the coating is unable to get between the tubes in the unexposed areas of the header.  If rust occurs, it will travel into and under the coating and create a stain.  When you are ready to start the car after storage, wash the WD-40 off by following the cleaning procedures.
Cleaning:  Road grime / Oil / Grease / Surface deposits (surface rust) from water or other liquids
      Use an environmentally safe Orange Cleaner Degreaser, warm water and a soft cloth. Two or Three cleanings may be required. Be sure to dry thoroughly.
      Use cleaning compounds like, Nevr-Dull, Mothers or Wax Shop and about 15-20 minutes of elbow grease.
      Stainless Steel:  Nevr-Dull Wadding Polish
Polish to Revitalize Coating
      Nickel Chrome Plating:  Bluing / discoloration is inevitable. You cannot remove it, although there are products that claim to do so like, Blue-Job Chrome Restorer.
      Ceramic Coated / Polished Ceramic Coated:  Mothers PowerMetal or Nevr-Dull.
For More Aggressive Cleaning:  Stains / Baked-on Oils or Fluids / Melted-on Microfiber Towels or Plastic Grocery Bags (Yes, this happens a lot)
      Try a Super-fine "0000" Steel wool pad or use an Ultra-fine Scotch-brite pad.
      If all else fails, spray paint!  Use Krylon 1402 High Heat Spray Paint – Aluminum color. Once headers heat up, color will or should blend.
 Unfortunately, you cannot bring back a “High Luster” Polish (“C5” coating option) appearance.
Offline Oldschool
« Reply #2 on: December 18, 2009 - 10:20:35 AM »
Thanks my friend....    :cheers:
Ken  --  In Georgia
Offline vinb
« Reply #3 on: December 20, 2009 - 06:34:06 PM »
I use Nevr-Dull on my coated headers, works great...
Offline 72rtchallenger
  • 72 to 70 clone
    • cardomain
« Reply #4 on: December 20, 2009 - 06:43:04 PM »
I have used rubbing alcohol but it is alot of rubbing but worked well
72rtchallenger
what happens in the garage
stays in the garage
wagesofsin
« Reply #5 on: December 20, 2009 - 08:14:43 PM »
whatever you use make sure they are warm when you clean em, leeches the oils out, and removal is easier. and yes it works
Offline BIGSHCLUNK
« Reply #6 on: January 02, 2010 - 10:08:23 PM »
I've used the nevrdull on things .. works good!
Hope Kim gets the DART lookin good!  :2thumbs:
                                             [o o o o]
                                                  OO
                                                  OO
                                              [o o o o]
